Kevin Weddle
- Feb 23, 2004
- 1,620
- Joined
- Feb 23, 2004
- Messages
- 1,620
I have this idea about the operation of opamps. We all know the input transistors are low current. But how accurate are they. We all want to believe that they are perfect. But I think the manufacturing process for these devices may not be as good as the higher current ones. Specifically their high beta creates a problem. By sheer means of the number. You take a beta of 500 and the base current is one then the number of the collector current is 500. You take a base current of 2 and the number of the collector current goes to 1000. It is sort of like the high gain principle in opamps. When you gain the signal at a higher number, you might get a gain of 20k or you might get a gain of 25k. If the gain is low, then you might get a gain of 20 or you might get a gain of 25. Just look at the difference in the numbers. So what I suggest is that by the sheer value of the numbers, you can expect a certain amount of error.
