SMD Device Marking Code
davidge
Sep 2, 2011
Does anyone know what is the device that has marking "LAC" on it? It is SOT23-5 package.
David
My information suggests is could also be an RP171N591B (5.9V 150mA)
http://www.dz863.com/datasheet-8205207663-RP171N591B_150ma-10v-Input-Ldo-Regulator/
or even an XC6219A432MR, which is a 4.3V 240mA reg. It's also on an sot-25 package which appears to be similar...
Since they're all LDO regulators, you can probably get a good indication of which is the most likely from the input voltage. ...And from the way they are connected in the circuit.
OLIVE2222
Oct 2, 2011
690
The RP171N591B as a 5 digits marking. LAC + 2 digit for the lot number
The XC6219A432MR as a 4 digits marking.1 L digit marking for the product serie + 2 digits for the voltage + 1 digit for the lot number.
cheers,
Olivier
Your information sounds better than mine :)
What is your source?
No, what I meant was, what is your source for the cross-reference information between case markings and devices?
OLIVE2222
Oct 2, 2011
690
Steve,
misunderstanding on my side. In fact I just Google it. With LAC SOT23 query it's the second result. I find this is better than dedicated tools as it also drill inside datasheets and it's more up to date. But at the end you find more candidates than me ! :)
Olivier
I should add that to the sticky thread!
OLIVE2222
Oct 2, 2011
690
Sure, it will help to promote this Californian start up company :D
