SMD Identification!!!!
Surf Rider
Sep 16, 2013
5
Hi Chaps,
I require a little help identifying some components on my circuit board. The first two have manufacture codes on them but I have had no luck at all finding any information out using them. The "V3F P119L" is in series with the circuit and then to a regulator after this.
The second one which has "GP111 (I think)" is in parallel with the circuit where the 12volt feed comes onto the board.
This little chap has no marking on and is about 6mm in length x 2mm height x 2mm in width. from what I can tell it test like a diode with my meter only allowing voltage through one way. It is in series in the circuit with some "MULTICOMP - ES2G - DIODE, ULTRA-FAST, 2A, 400V " but it is not the same size as those.
Any help would be gratefully appreciated.
Cheers :confused:
