[email protected]
- Jan 1, 1970
- 0
Hello!
My first SMPS (switching mode power supply) design's conducted signal
noise, major one is the 260KHz, which is the SMPS switching frequency,
is over the CISPB standard by 2.48dB.
How do I suppres the 260KHz signal down which is conducted back to the
power supply line?
The chip I used is the National LM2672-12, for a 12V DC output. The
current consumption of the whole circuit is about 120mA-130mA. Power
supply in is 24VAC.
There is a 220uF SMD electrolytic capacitor and a 100nF SMD ceramic
capacitor served as the input cap. The 220uF cap also serves as the
filtering capacitor after a half bridge rectifier/diode.
The output cap I used is the same 220uF SMD electrolytic capacitor.
Its impedance is 180mOhm @20degC 100KHz. Datasheet link for this cap
is http://www.farnell.com/datasheets/61167.pdf.
There is another 100nF capacitor in parallel with the 220uF output
cap.
There is a gound plane on the top of the PCB, but not very big, and
its shape has changed to a very uncommon one to allow other wider
pads. The ground plane shape is like a "O", but with a small open at
the left bottom corner.
Cheers,
Jerry
power supply line?
supply in is 24VAC.
cap.
Cheers,
Jerry
