Snubber Circuit For induction motor
steve_venkat
May 22, 2017
30
Hai,I'm trying to drive an bi-directional induction motor with BT136 triac,but often the TRAIC is blown up.So I tried to use the snubber circuit to avoid this issue.But I'm new to snubber design.
So please advice is this circuit is corrector have to change the circuit.
The induction motor is 230VAC operating and consume 1.4A in normal operation.
Minder
Apr 24, 2015
3,561
What type of motor is it, if bi-directional, then I assume it is a PSC motor if induction, if so you would need to swap the start run winding's over to reverse.
A snubber around 150ohm in series with a .1uf cap for a start might solve the failure problem.
M.
steve_venkat
May 22, 2017
30
M.
Can you check the diagram which attached in previous post..Is it correct..?
ramussons
Jun 10, 2014
475
The Snubber (with around 150 Ohms and a .05 uF in series) should be Directly Across the Triac. In your schematic shown the Opto is being fed from the tapping of the RC combination.
steve_venkat
May 22, 2017
30
Is this circuit is ok..?
