soft start circuit for angle grinder - anyone done one?
Des Bromilow
I've got an antique angle grinder which does not have a soft start - as
a result the retainer siezes on and it's a right PITA.
Knowing modern grinders have softstarts built in, is it possible to
retrofit a softstart circuit into an older grinder?
The grinder is single phase 240 VAC and about 2kW. I've sent Makita an
email, but heard nothing back yet.
If it's not something easily built, does anyone know of a module which
can be added in from another model? links to part numbers, cct
schematics etc? All I've found googling are audio ccts - not single
phase power units.
Des
Grant
Wimp, just get a good grip on the thing before turning on the power ;)
Yes I know they like to try jumping out of your hands
Solutions? How technical are you?
Series resistor shorted out by a timed relay? Simple but mechanical.
Current surge limit thermistor as used in power supplies? Bad because
they need a long cool-down period after use, or use a timed relay to
short the thermistor during use so it's cool for the next start.
Some sort of TRIAC based slow start? Haven't seen one, but then I
haven't been looking for one either, it's a simple enough problem.
If there's room, otherwise inline.
Ouch, big enough :)
phase power units.
Start by looking for a drill speed controller, and think of sending a ramp
voltage into whatever the speed wiper goes into, but it depends on the
circuit you start with.
Grant.
F
F Murtz
His complaint is that it tightens the blade to much, getting a grip has
nothing to do with it.
Grant
learn to spell (s/to/too/)
Grant.
F
F Murtz
Grant.
The extra o just wastes bandwidth just like this post (and your post)
Jasen Betts
do it up tight before you turn it on.
All the 100mm cheapies I've used had no such thing, I never used
the spanner just gripped the disc and turned it hand tight.
after use it was still hand-tight.
If the disc slips at startup it will overtighten the nut.
It's a big one then, you've got to get the nut really tight on those,
two-hand tight. You say it's old, perhaps you need to replace the
retainer nut and/or spindle. Does is look worn ?
phase power units.
go to makita and grab the spare-parts diagrams, if it's not a feature
of the rotor their replacement part for the new models may fit yours.
⚂⚃ 100% natural
--- news://freenews.netfront.net/ - complaints: [email protected] ---
phase power units.
Des
I have an endico angel grinder which doesn't require this so never tried this before.It is long lasting and durable.
http://www.endicopowertools.com/electric-angle-grinder.php
JW
I'll take thing that a spammer would say for $100, Alex.
