soil moisture sensor
sibghat
Dec 9, 2010
i want to design soil moisture sensor .....suggest any circuit ???help me out wat kind of probe i must use???
14,485
ohhh gosh a damp detector was my first serious electronic project some 40 years ago (showing my age) it was for detecting dampness on walls of buildings.
in practice it would work for your need as well so long ago I cant remember much about it.
for your use you need a couple of ... preferably stainless steel spikes ( so they wont rust) say 8 - 12 cm long and mounted ~ 3cm apart. That will do for the probes
have you googled soil moisture sensor circuits ?? probably a good place to start :)
Another option is to have a spike that is insulated to almost the end and a sleeve over that so that only a single probe is required.
An alternative is a plastic tube with a number of conductive bands around it, however that really only works well in liquids (and thus obviously not for detecting moisture).
shrtrnd
Jan 15, 2010
3,902
It's a simple circuit.
Start looking for circuits using a 4011 CMOS IC. I saw somebody make one using 4011's also.
