Solar lights charging board component
kwicher
May 11, 2020
7
Hello
It is a noob question. I am trying to repair my garden solar lights and they have a small very simple circuit with something that most likely is a voltage booster.
I tested the output produced from the system and it is only 0.5V or so which is obviously too little to power the LEDs. Solar panel output is 5-6V and the battery is LiMH 1.2V.
So for me, it looks like the booster is broken. I thought of replacing it or building from scratch but there is not a number on the part. Would you have an idea of what it could be? Pictures attached.
Thank you
Martaine2005
May 12, 2015
5,318
Hi kwicher,
Somebody will be able to decipher the 8 pin dip fairly easily.
But in the mean time, have you checked the switch? it certainly looks corroded and rust evident on the inside.
Try bypassing the switch and then check the output.
Martin
kwicher
May 11, 2020
7
Hi kwicher,
Martin
Hi
I checked the switch it is not a problem. Broken chip?
Best
K
73's de Edd
Aug 21, 2015
3,730
SIr kwicher . . . . . .
[ [ [ [ [ the battery is LiMH 1.2V ] ] ] ] ]. . . . . . . .e r r r r r r r . . . . NOPE !
One would initially think that your units 8 pin dip packaged switch mode Eye See, MIGHT ? possibly be a Tejas Instrumentations type SN6501, using its internal oscillator and internal FET driver to drive / ring that external inductor (120 uh) and rectify its ringing amplitudes with a schottky diode to acquire a boosted output voltage for the LED lite..
RE . . . . http://www.ti.com/lit/ds/symlink/sn6501.pdf?&ts=1589252334576
HOWEVER . . . . that device is only being offered in a 5 pin backaging . . . no 8 pin dips, so that would not be the mystery deee-vice.
And then there is being the LSP6501, but it requires far more support components than are shown being used here.
Re . . . . https://www.datasheet.live/index.php?title=Special:pdfViewer&url=https%3A%2F%2Fpdf.datasheet.live%2Fdatasheets-1%2Flite-on_semiconductor%2FLSP6501MSAC.pdf
Then, as per your comment on the IC being bad . . . . .BUT . . . . as conservatively as it is being used here, I can't see that, unless that is being with a dee-veloped internal manufacturing / quality defect.
NOW . . . .what I really-really-really-really-REALLY think as being the root problem, is the quality factor of the units supplied rechargeble cell.
Why not pull it and put in an alkaline 1.5 cell, and then PROBABLY see the unit putting out light again.
While you are at it, and if you happen to have a well developed "Junque electronics equipment pile for scavenging", why not see if some piece of equipmemt will provide a 33 or 47 uh choke coil . . . .which you replace that 150 uh unit with and then experience and increased light output .
If the stock supplied rechargeable cell is deficient . . . . . lets talk about that later.
Needless to say, these units work best if sited to receive FULL sun thru the day . Partial tree shade time REALLY fouls up their performance.
Thaaaaaaaaaaaaassit . . . . .
73's de Edd . . . . .
If 4 out of 5 people SUFFER from diarrhea . . . now, does that mean that ONE of them actually enjoys it ?
kwicher
May 11, 2020
7
the battery is LiMH 1.2V ] ] ] ] ]. . . . . . . .e r r r r r r r . . . . NOPE !.
Ni , Li - who cares :D
I went through the same thought ... Google ... process.
THe whole solar/battery unit is of poor quality though it worked for a year or so but second English winter killed it and you saw the rust.
I might be a noob :) but I tried that to no success - the unit still has only the same voltage at the output as the battery.
Not yet, building up ..
Cambridge is quite sunny so that is not a problem.
Thanks for all the comments
krzys
