Solar panel , grid tie inverter mismatch ...
oz93666
Dec 7, 2014
38
I have a 1200 W grid tie inverter ...(WCV1200) it has 4 inputs , each one designed to take 300W ....input voltage is 22-50V
My panels are 100W (21V open circuit ) ...so I have to put two in series to get the inverter to work , so I can put either 2 panels (200W) or 4 panels(400W) on each input ...
My question is if I put 4 panels on each input would it overload the inverter on the rare occasion the panels deliver full power ...
If it would , could I put 4 panels on two input sockets , and 2 panels on the other two inputs , this would make max input at the rated 1200W ??? ....Many thanks...
You need the specs for the inverter.
Some will simply limit the power they draw, others will melt.
You're right. You may need to contact them and ask.
