Solar Panel with small hobby motor
Rifts
Sep 26, 2013
Hey everyone!
I'm just getting into hobby electronics and I have a quick question.
I have a 0.5W Solar Panel 6V and 1.5-3VDC Metal Gear Motor (both from radio shack)
why does the motor not work with this solar panel? Is the .5W to low to run the motor?
I'm confused because I know the solar panel works, it will light an LED fine. Also I know the motor works as I've attached it to a 3V and a 5V power supply and it runs fine.
I thought the 6V solar panel would be enough but does it have something to do with the .5W not being enough?
I hope this all makes sense, like I said i'm pretty new to this stuff.
Thanks!
also just incase it helps here are the links to the products
Solar panel:
http://www.radioshack.com/product/index.jsp?productId=12609999
Motor:
http://www.radioshack.com/product/index.jsp?productId=2102828
Well, the motor does not list a current requirement. It is likely more than the 80mA your solar panel will supply.
And by the way, why are you trying to run a motor rated at 1.5-3V off a 6V power supply? If the power supply could supply enough current to run the motor, it would likely destroy it.
