I am hoping people can correct my errors on the following information in the hope of getting a better knowledge
So far I know the basics. in all systems it is best to have 3 parts. the panels, the battery and a charge controller. So far my research suggests that a 1:1:1/4 ratio is needed that is a 300watt panel for a 300ah battery for a 75 watt load (in perfect conditions of course.)
But this varies if you wish to use the solar for longer or shorter periods of time and daylight hours, and of course if you want to upgrade the load.
If you wish to connect an inverter or use the mains to assist in charging I reccomend a qualified tradesman.
for smaller projects you can use solar panels connect to a diode to the batteries to limit backflow which will drain the batteries if the solar panels are not getting enough sun, In the case of powering up car batteries(or deep cycle batteries which are much more preferable) the charge controller acts as the diode as well as stopping overcharge and over discharge.
A decent charge controller will also have a temperature sensor as different temperatures affect how much the battery can store.
So far I have not found ANY inverter that endorses the use of refrigeration units like fridges, freezers or air conditioning units, as the "kick-in" current can destroy both the inverter and battery.
also I have found our local electrical supplier is not overly happy when people put in solar thinking they are helping. in actual fact the most power produced is outside the peak hours and thus is mostly wasted. most people don't have a battery bank that allows the grid to be fed power when it is needed the most which is typically 6p.m. - 8p.m.
PLEASE PLEASE PLEASE tell me more if there is anything
I would especially like to know the charge controller ratio. like what would be the maximum solar panel to battery ratio a 30amp controller could handle?
Also if I connect an inverter to the system will a 75watt inverter be good for the above setup? or would I need a bigger battery as the inverter would use up some power in the conversion?
