Soldering Iron Repair
GT
My Weller w100 is dead. I opened it and everything looks "ok". My
meter was dead so I couldn't check the cord. Any other suggestions?
TIA GT
John Miller
First, get your meter working. Or get a working meter.
Sofie
GT:
"looks OK" is not an indication that all is working properly..... a lot of
faulty components look OK with no signs of over heating or other obvious
defects. These things need to be tested with test equipment, a working
DMM or VOM test meter is required if you are going to effectively
troubleshoot this problem. First priority would be to repair your test
meter, borrow one, or purchase a new one.
Now I am thinking that if you are in need of this kind of advice that you
probably won't be able to fix your Weller w100 no matter how many working
meters you have. I could be wrong, please forgive me if I am.... and good
luck getting your soldering iron working.
Michael A. Covington
Most common failure is simply a poor connection of the tip to the rest of
the soldering gun.
Tom MacIntyre
TIA GT
How are the batteries in the meter? Do you have a low voltage bulb and
a battery to do a continuity test on the power cable?
Tom
