Can We Weld With a Soldering Iron?
maguirejames
Nov 2, 2022
Can We Weld With a Soldering Iron? and also what is difference Between Welding and soldering
Minder
Apr 24, 2015
3,561
Soldering is the 'whetting' joint of joining similar metals, IOW, the metals being joined do not experience any melting in the process.
Welding involves fusing (melting) the two metals together in some cases using a similar metal to provide the fusing process.
So no, you cannot weld by soldering.
walishahid333
Nov 1, 2022
8
Welding and soldering are both forms of metal joining. They both use heat to fuse two pieces of metal together, but the process and results are quite different. So Can You Weld With a Soldering Iron? - ElectronicsHacks
The answer is complicated. We'll discuss the basics of welding and soldering, and give you some tips on how to get the best results if you’re trying to weld with a soldering iron.
Minder
Apr 24, 2015
3,561
In the case of soldering and brazing the metals are not 'Fused' but joined by whetting the two surfaces in order to create a none fused bond.
