Soldering: Need Two More Hands(Part 2)
I'm in a *desperate* situation and really need a video of some sort
showing the art of soldering.
Six projects have hit a wall because of my inability to solder leads to
fingerboards and I really need help.
I've read every "How to" I could find and studied the advice from here
and the classic video game group, to no avail.
I'm using stranded wire and I'm starting to wonder if the wire just
doesn't solder like it is supposed to.
I been using 60/40 rosin core(from various suppliers). I constantly
clean the fingerboard, and clean and change the tips. I was using a 30w
iron, and have tried(for the last couple of hours) using a cheap Radio
Shack station that switches between 20w and 40w, but the 20w doesn't
melt the solder and the 40w tends to take too long and then turn the
solder into vapor..
If I manage to get it to melt, the solder will tend to solidify into a
ball anywhere but on the wire I'm attempting to connect to the
fingerboard. Or on those occasions when it is fluid *and* in the
correct location, I'm burning my fingers(trying to keep the insulated
wire from lifting out of position) long enough for the solder to
solidify.
Basically everything that can go wrong does go wrong.
Can anyone make a video? I *really* need to see how this is done,
because for the life of me I cannot figure out how people with only two
hands can get the soldering iron, solder, wire, and work to come
together at one location, or fast enough so that the solder doesn't
solidify before the connection is made.
Perhaps my hands just aren't capable of certain things others take for
granted. But If I don't figure this out soon these fumes will kill
me.(A fan only does so much).
Any help would be appreciated.(I really need a video).
Darren Harris
Staten Island, New York.
Simon Scott
Hey
Maybe not much help to you, but I commonly solder JAMMA fingerboards.
What I do is locate the pad to solder to, and give it a light rub with some
find grit sandpaper, and then clean with isopropyl. Then I stick the
soldering iron on it and rub it around a bit, just in case there are any
remaining impurities on the surface. Then I 'seed' the pad with a blob of
solder, which should flood to the edges of the pad and not sit like a
little ball (which would snap off).
Finally I grab the wire (which should has a little solder on it itself) in a
pair of needlepoint pliers and stick it on the solder on the pad. Then
simply press it down with the iron.
Im a complete amateur, but this works for me.
John Fields
solder into vapor..
solidify.
1. Get a soldering sponge and get it pretty damp (not soaking wet,
damp).
2. Plug your iron in and let it get hot.
3. Tin it. That means touch some solder to the tip until it melts
and flows onto the tip. Id you can't do that, your tip is dirty
and you'll have to clean it. To do that, I scrape the edge of a
common screwdriver along the tip to get the crud off of it, and
then hit it with some solder. A little at a time. Scrape until
some crud is gone, put a little solder on the tip,then scrape
away a little more gunk and repeat until the whole tip is bright.
Once you've got it like that, clean it by rubbing on the sponge
and put a new layer of solder on it. Your iron is now tinned.
4. Strip and tin the wires. Use a good stripper that won't nick the
wires and remove as much insulation as you need to. Then, if you
have any strands sticking out, twist them back so they follow the
lay of the rest of the strands. Once you've got that done, take
your solder and lay it down so it sticks out over the front of
your bench, then touch your wire and the soldering iron to the
solder at the same time, at the same place, so that when the
solder melts it'll flow into the wire. Your wire is now tinned.
5. Tin the finger strips. Touch the iron to where you want to
solder the wire and put a little solder where they're
touching. The idea is to flow a _little_ solder onto the
fingerstrip where the wire will be connected.
6. Solder the wire to the fingerstrip. Lay the wire down on
the tinned part of the fingerstrip and press down on it _gently_
with the iron. If you do it right the solder in the wire will
melt and cause the solder on the fingerstrip to melt as well.
When that happens, hold the iron on the joint for a second or
two, and then quickly remove it WITHOUT DISTURBING THE WIRE.
Keep the wire from moving with the hand holding it NO MATTER
HOW HOT THE INSULATION GETS, and If you did it right, when it
cools the joint should be nice and shiny. If it isn't, unsolder
it, remove the old solder from the fingerstrips with braid, retin
it, heat up the wire and shake the old solder out of it, retin it
and try again.
The most important thing is to get the joint hot enough before
you remove the iron, and to keep it ABSOLUTELY still while it's
cooling. The other most important thing is to keep your iron
clean and well-tinned. If you don't have a soldering sponge,
get one.
Chris
solder into vapor..
solidify.
Darren Harris
Hi, Darren. Google is your friend. The _first_ link shown on the
search
"How to solder" video
was
http://radiojove.gsfc.nasa.gov/elab/soldering.htm
Try it. It works. Download all six parts.
Try this, too:
http://www.epemag.com/solderfaq/default.htm
Even though it's not a video, it's good.
Also, I'll bet you've either got oxidized wire or oxidized
fingerboards. Go through Mr. Fields' procedure, and see if one or the
other doesn't wet. I'll bet that's your problem.
Good luck
Chris
Bob Masta
On Sun, 09 Apr 2006 19:01:13 -0500, John Fields
and try again.
get one.
To add to John's excellent advice, you may want to add those
two more hands you mention in your header. They sell little
stands with arms that hold alligator clips that can grab small
boards while you solder. Or you can probably rig something
up with a separate alligator clip or two. (They may be already
on the endsof an odd cable you have laying about.) Either way, you
will have to be careful not to pinch the wire insulation too close to
where it is heated, or the clip teeth will push through the softened
insulation.
Best regards,
Bob Masta
dqatechATdaqartaDOTcom
D A Q A R T A
Data AcQuisition And Real-Time Analysis
www.daqarta.com
Home of DaqGen, the FREEWARE signal generator
N
Noway2
solder into vapor..
In addition to the advice in the other responses, I would suggest that
you may want to obtain some 63/37 solder as it might be a little easier
to work with. 60/40 goes through a "plastic" stage when it cools,
during which time it is vulnerable to movement which will cause a
disturbed joint. Disturbed joints look a lot like cold solder joints
in that they are lack luster and have a rippled appearance. 63/37
solder, which is a eutectic goes directly from a solid to a liquid
without this plastic stage.
You may also want to see if anyone nearby teaches any IPC soldering
certification classes. While you may not be interested in the
certification, I took one on SMT soldering and it made all the
difference in my ability.
Here is a link to the company I took my training from:
http://www.smt-network.com/training/schedule.htm
Most of their classes are in Raleigh, NC, but they do have classes in
other locations. At the very least, it will give you an idea of what
kinds of classes are offered.
N
Nick
Good advice here. Something else that may help keep things clean is bit
cleaner. I never used this as far as I can remember with my old weller
iron that my Dad bought me as a kid, but with a recent antex iron, I
was inexplicably having a lot of trouble with keeping the bit clean on
some work I was doing. So I bought a little tin of bit cleaner and it
does the job fantastically. You shouldn't need to use it often, but if
the bit does get messed up then this will clean it in a couple of
seconds and leave it lightly tinned, shiny and good as new. As others
mentioned, a damp solder sponge (not a bath one!) is essential too. If
tinning wires, depending on the number of cores you may get a rapid
build up of excess solder on the bit. Wipe this off to the sponge after
tinning each wire or two so that you're applying a fresh bit to one
side of the wire and new solder to the other side, rather than any
solder left on the bit from previous wires.
This page from Rapid here in the UK shows the bit cleaner item. It's a
tiny tin. Multicore are in the UK, but I expect that you get the same
or a similar item from your local supplier and it might come in handy.
http://www.rapidelectronics.co.uk/r...CAT_CODE=30455&STK_PROD_CODE=M30243&XPAGENO=1
Good luck with the soldering!
blah
solder into vapor..
solidify.
From the sounds of it, you really need to stop being cheap and get decent
equipment.
First, make sure you have the right equipment to do the job. There is no
substitute for the right equipment. Let me assure the right equipment
doesn't include a cheap Radio Shack soldering iron. If you are serious
about soldering, get a decent soldering station, a Metcal for instance
or at least a Weller.
Second, get decent wire... Teflon coated is much nicer than PVC (not to
mention probably safer for a whole host of reasons). The right wire
might be stranded or solid depending on what you are doing.
Third, get all the other stuff you need to properly do it. Tweezers,
a helping hand, a vise, isopropyl alcohol, water dispenser, solder
paste, sponge, solderwick, liquid flux (very useful for the solderwick),
boars hair brushes, a magnifying lamp, and proper ventilation is always
nice too. In theory (and I know its asking a lot) you should also be
operating on an ESD safe properly grounded mat with a ESD bracelet.
Now in terms of technique. The first thing to do is use the right tip
for the job, keep the tip clean and then tin it with solder. Now
tin the leads of whatever it is you want to solder, then hold the
parts together in the appropriate position with tweezers, tin the tip
of your iron, and push the two pieces together with the iron and let
the solder flow between them. Then remove the iron, while keeping
the pieces perfectly still and allow them to cool. If you are soldering
an IC, go for the corners first and use it to tack the part in place.
Having the right equipment will help more than you can believe.
Rich Grise
damp).
and try again.
get one.
Excellent advice! I've embellished the subject line a little to make it
more searchable on the archive.
I would like to add one thing, however - very many years ago, I got a
little tub of something called "TipTinner" at RS - it's a combination
of flux and little solder granules that you stick your iron into and
it cleans and tins it. They still have something fairly similar, albeit
when I got mine it was about a buck:
http://tinyurl.com/pfekz
Look in the yellow pages to try to find an amateur radio club or
electronics special interest group, or go to a local repair shop, and
watch somebody solder.
And, of course, practice, practice, practice. ;-)
Good Luck!
Rich
John Fields
There's also the old standard:
http://www.glassmart.com/salammoniac.asp
although I prefer the mechanical method of gently scraping the tip.
