Soldering station smoking problem?
Pexy
Feb 21, 2016
142
Hy guys i just bought today a new Velleman VTSS7 soldering station and when i turn it on it started smoking realy badly and smells like burned plastic where the heating element connects to the handel. Is that normal?
Gryd3
Jun 25, 2014
4,098
No.
The heating element is in the top of the device. The metal is usually perforated to allow heat to dissipate before it gets to the handle. I've seen models where this is not the case and the handle tends to get quite warm... but if it's melting or smoking, its a big problem!
Is it adjustable? You didn't accidentally buy a 110V iron and plug it into a 220V outlet?
Pexy
Feb 21, 2016
142
No.
Yes its ajustable, and its 230V on input as is my output voltage on mains
Gryd3
Jun 25, 2014
4,098
I've got to ask the obvious. What was the temperature set to?
Pexy
Feb 21, 2016
142
1st time to max and 2nd time to medium and low
Pexy
Feb 21, 2016
142
Ok... Do you have any point to make with the manual because I have it.
Pexy
Feb 21, 2016
142
and DONT set the replacement to max !!
I won't, but it should work on high temps without smoking. My brother has the same price soldering station and it works on any temp without problem at all.
14,486
I won't, but it should work on high temps without smokeing. My brother has the same price soldering station and it works on any temp without problem at all.
that means very little, unless it's the identical make and model
14,486
well it was for the benefit of everyone else in the thread
and what you should have posted in your OP
I have to ask. Are you sure there was not some packing material on the iron when you fired it up?
Pexy
Feb 21, 2016
142
Yes im 100% sure there was none packing material on the iron, i even did a tear down of the handle and could'nt find anything
