Solid State Relays
tiraas
Nov 26, 2012
Does anyone know of a solid state photo relay that can receive 3-5v 10mA input that can do 5 - 25amps dc switching for less than $4 each?
If it is multi packaged then $4 per channel
An alternative would be an AND gate of some sort with 2 optical isolated inputs to do the same as the relay, but my design capabilities are limited since I am a software programmer.
I have a 64x64 array of outputs so I need essentially a 4096 relay matrix.
However I need to keep the costs minimal.
The 4096 nodes are sequentially addressed in columns of 64 usually for 30 seconds per row.
I thought 64 relays could do this, switching to 0v and ULN2803's providing the +, although this isn't an isolated solution.
If anyone can think of a better solution, I am all ears.
Thanks, tiraas.
This is close to your price range (cheaper in quantity)
Even cheaper in large quantities.
As to how far you'd trust it...
This may be the same thing even cheaper!
Gpino
Nov 27, 2012
11
Load that you are in charge?
up to 100mA can use the TLP3061/62/63
1A is if you can use AQH3113
over or I'll build an optocoupler is a thyristor
if you do not find them for a few pieces I can provide that information
hello Gpino
