using solid state relays with servos
mikgol
Jul 6, 2013
87
Hi there,
I'm using an MG995 servo, which is rated at 6v. To power it, I'm using 4 (new) AA batteries, which should provide 6 volts. The servo only comes on periodically, so to stop the batteries from going flat I've hooked up a solid state relay to turn power on/off to the servo.
The servo is running very weak (with fresh batteries) - is it possible that the solid state relay has a voltage drop or something that's causing this?
bigone5500
Apr 9, 2014
712
You could probably measure the voltage to the motor as it is running. This would show if you have voltage drop. I would think that a solid state relay would definitely have a small amount of drop.
Do you have a part number to the relay you are using?
bigone5500
Apr 9, 2014
712
Thanks for the reply Jared. The solid state relay is a HFS40 (http://pdf1.alldatasheet.com/datasheet-pdf/view/194494/HONGFA/HFS40.html) - I can't find anything about voltage drop in the datasheet, but maybe it's implied?
I'm turning it on/off with and arduino, which is why I went with a 5v solid state replay
I think I could be wrong about measuring the voltage drop. However, your relay has transistor output. So I am not sure about how much drop there will be in your circuit. I'll take a guess and say not more than .5 volts.
mikgol
Jul 6, 2013
87
I've got the 5v version. Hmm, judging by that post I'll try putting a 1n4007 diode across it to see if that helps.
Is it "bad practice" to use solid state relays to power motors etc? (sorry if that's a dumb question)
GPG
Sep 18, 2015
452
There's a max voltage drop of 1.5V in the datasheet.
mikgol
Jul 6, 2013
87
Ahh yep! I see it now :) That would explain it then. I'll chuck in another AA battery to compensate. Cheers for the help guys
