Solvent to remove glue from PCB?
Mr. Land
I thought for sure I'd find the answer to this already posted here,
but I didn't, so...
I'm working on a small PCB that has an 8-pin SMT IC on it. The
manufacturer chose to glue a small piece of black thin cardboard on
top of it, probably as a cheap insulator. I've gotten that cover off,
but the IC and surrounding circuit board are still coated with the
dried glue that was used on it (it's especially gooped around the IC's
pins).
The glue is a yellowish-white and very, very tough. It seems very
much like the glue I've often seen used to glue larger components
(like big electrolytic cans) to PCBs to prevent them from moving.
Is there a well-known solvent for dissolving and removing this glue?
I've tried:
- PCB cleaner (Electro-Wash)
- Denatured Alcohol
- Flux Remover
....none of these seemed to affect the dried glue at all.
Thanks.
Dave Plowman (News)
I've tried:
- Denatured Alcohol
- Flux Remover
Have you tried a label remover? That solvent works with many glues.
Boris Mohar
but I didn't, so...
pins).
I've tried:
- Denatured Alcohol
- Flux Remover
Thanks.
Heat. It could be a hot melt adhesive. Touch it briefly with soldering iron
tip and see if it melts quickly.
W
whit3rd
I'm working on a small PCB [on which]
manufacturer chose to glue [something...]
I've tried:
  - Denatured Alcohol
  - Flux Remover
The PCB cleaner and denatured alcohol are exactly what the
mass produced circuit board was cleaned with at the factory, of
course; no surprise that the glue didn't come off with them.
Flux Remover can be any number of things (Freon? Methylene chloride?)
but you'd have to look at the label to tell.
I'd try paint thinner (or other naptha solvent), and acetone/ketone
(like
lacquer thinner), or even just a hotair blower and a brass-bristle
brush.
Those solvents are flammable, of course, so no sparky blower motors
while they're in play!
Methylene chloride (old-fashioned paint remover) might still be worth
a try, if you have proper ventilation. And then maybe toluene or
heavy alcohol (like glycerine).
Mr. Land
All excellent suggestions - thank you very much folks.
