FuZZ1L0G1C
- Mar 25, 2014
- 366
- Joined
- Mar 25, 2014
- Messages
- 366
Hi. I've been doing a lot of web research lately, regarding the best method of creating clear, sharp PCB traces at fine resolution.
Currently, I have no sophisticated UV equipment or materials, which is why I'm researching what to get.
My current modus operandi is the old-fashioned and clumsy Dalo-resist pen and rub-down pad / track transfers, and Ferric Chloride etchant.
A (clean) plastic cat-litter tray is used for larger boards, and Tupperware "lunchbox" for mini-PCB's.
These are silicone'd with perforated fish-tank airlines, fed by a fish-tank filter oscillating air-pump.
This 'bubble-tank' matrix helps the etching process.
An unused (inherited) dinner-server tray warmer plate thingy on low temp keeps etchant at lukewarm temperature.
A home-made 12 V solenoid is used for auto-rocking the entire warmer / tray, but due to resonance wave buildup splashing, I generally use occasional hand rocking.
Reading E.P. posts and other websites, the Laser toner iron-on transfer method seems to create fine details.
I'm unsure whether my two Samsung Laser printers have suitable toner, or if the print transfer materials mentioned are even available.
UV, on the other hand, seems (to me) to be a more reliable method, without 'dissing' the iron-on toner method.
(As a noob to advanced PCB production, these are just my personal assumptions).
Many eons ago, I had a B&W photographic darkroom, with Enlarger, trays, developers, etc.
Therefore I grasp the concept of the UV / photo-resist method.
I wonder if an enlarger / slide projector would work? Or bright sunlight?
Suppose that UV lamps are not available for the former, and the latter (sun) would be too 'spread', causing undercutting.
Maybe the sun method could utilize a black 'hood' to block side radiation?
We have a PCB service via a nearby Electronics Component Supplier, but my idea is to make my own in the evenings, on weekends, or just to create anytime 'on-the-fly'.
I was thinking of building my own UV source using several portable 'money detector' (3 W?) UV tubes stripped from their plastic "torch" housings.
Another UV source is the 220 V AC 60 W "black-light" globe sold at some audio / Hi-Fi retailers as part of "DJ/disco" accessories.
A website I was browsing (?Wiki How-To?) also mentioned face-tanning UV lamps.
The articles also mentioned the problem of undercutting due to offset light sources "creeping" under the non-exposeable masks (see my explanatory sketches).
Now I have a few questions which I didn't see answers to elsewhere (regarding UV exposure method):
Does one need a blacked-out darkroom, or will photo-resist board be safe under normal indoor lighting (combo of 1 x 100 W incandescent standing shaded floor-lamp and 6 x energy saver 'fluorescent' ceiling globes, individually switchable).
The article re undercutting makes me wonder - is a flipped printed image placed face down on photo-resist, or is there a clear acetate thickness between (positive image up)?
Regards,
Clive.
Regards,
Clive.
