Sylvia Else
- Jan 1, 1970
- 0
Michael said:They don't have to. The cast all read their scripts, and know what
to do. ;-)
And the aliens in many cases not only speak English, but do so with an
American accent.
Sylvia.
to do. ;-)
Michael A. Terrell said:Don't you get tired of being probed? ;-)
Paul said:Evidently you haven't been watching Dr Who.
Michael A. Terrell said:How can your DNA tell them what's in your mind?![]()
Or a mind wipe? ;-)
Phil said:Your part of Europe was obviously quieter than most.![]()
Robert said:<grumble>.."functional"..guess one better start to define (nominal)
capabilities of that computer first.
Robert said:Noting wrong using a solar cell using your condition that the device
"be secreted from human tampering" for that 1000 years.
John said:Good cells are fairly klunky monocrystalline silicon PN junctions.
They'd probably work fairly well after a million years if stored
properly.
Robert said:Sine i am a baer, may i growl and say "Gurr-avity"?
What does the machine have to do? Mechanical stuff (gears, cams,
punch cards) lasts a long time. It could be powered by gravity.
George H.
Robert Baer said:* Sorry, NASA has seen whisker growth in their satellites..
Tim Williams said:Al Po's?
Generally considered as good as tantalum and fairly indestructible, aren't
they? Kind of new to use for millenium hardware though.
Yeah, even worse! I was probably thinking of this toy
I guess an artillery shell leaves in even bigger of a hurry, but
doesn't *keep* accelerating... More of a "jerk" situation?
Not if you use them right
Well, then they still may fail ;-)
Just that you won't know about it.
s/know/care/
But on the more serious side, I have never had one go kaput,
I like them because of low ESR and small size.
They do not dry out, some have been on for 20 years...
I have seen exploded ones cause damage in equipment, most likely because they were put in in reverse...
I put one in (actually a whole series) in reverse myself one day, because the + was marked with a big --
That came out when the first one was tested, and the resistor in series with it burned a hole in the PCB.
That was supposed to be a fusible resistor, I have now learned that metal film resistors do not fuse very well.
A number of the original Tek tube scopes (517? do not remember
numbers it has been too long) still work only needing capacitor forming
via slow increase of AC via triac.
It's all about maintenance. Wonder how often the bellows had to be
replaced/rebuilt? Probably even some pipes?
The original 'lint' traps? ;-)
