Sony Audio amplifier takes long to "warm up"
I have a background in electronics but not in audio amplifier.
I have a Sony Audio amplifier, a 25 years old model. I turn on the
power and it takes 20 to 40 minutes to hear the music. Just before I
hear the music, There is a ZZZZZZZZZZZZZ then a CLICK. Each selection
(Tuner, Aux or Tape) works or does not. Once the amp works, it works
until I turn it off.
On what stage, from the power supply to the audio output, I should look
at?
What type of component I should look for ( capacitor, relay,
transistor)?
Do you have a suggestion of a web site?
The purpose of this posting is to understand how an audio amplifier
works to repair it.
at?
transistor)?
Electrolytic capacitors, probably. I'd guess in the power supply, the
audio output and the protection circuit.
Leonard Caillouet
Sounds like a weak cap on the relay drive circuit.
Leonard
sofie
a good possibility.... or just as likely: cold, cracked or otherwise faulty
solder connections on pcb near and around the high heat producing power
resistors, semiconductors, etc.
Dave Plowman (News)
Sounds like the speakers are fed via a relay - commonly to prevent a thump
in the speakers at power up time. There will be a timing circuit
associated with it. May be even they trip out if there's a large DC offset
through the amp.
