Sony CDP-CX400 CD Changer
chowlett
Dec 2, 2018
I have a Sony CDP-CX400 CD Changer that will not power off, open, rotate or play a disc. Have no idea what the issue is. It worked perfectly the last time it was used. Anybody have any ideas on what the issue could be?
kellys_eye
Jun 25, 2010
6,512
How do you control it? Remote? Keyboard?
If it's a remote, are the batteries ok? If it's a keyboard, has any key stuck down (this will stop other keys working).
chowlett
Dec 2, 2018
It has a remote & the batteries are fine. No keyboard. When you press any button on the player nothing happens.
kellys_eye
Jun 25, 2010
6,512
Is the remote working? View the end of it using your mobile phone camera - you should see the IR LED working when you press any button(s).
Can you 'reset' the player by turning off at the mains and powering up again?
Jason R
May 19, 2019
Drive Belts are done, practically erode into goo (really nasty tary gunk).
Amazon sells the replacements, you'll need 2, for about $12 per pair: Part X001PK6EIR
The surgery is in depth, complete disassembly of the unit required, a few dozen P2(regular philips) screws, about 2 hours. Acetone (nail-polish remover) for old belts removal/discard and cleaning of drive pulleys.
Aptitude Req'd: 5 of 10 (attention to disassembly essential, then reverse order)
Sadly in my case the CD reader was also deteriorated (skipping, dodging tracks) so restoring the turntable's motion/function was not the whole of the repair. Since the above required demounting the laser-side of the reader it's likely a better economy to address it's replacement in due process.
It's no wonder, though, that SONY no longer mfgs these units, as nifty as they are.
Good Luck!
