Need Help in repairing a Sony CDP CX-350 Mega Storage CD unit
DKasey563
Aug 18, 2021
My 300 CD player makes a loud hum when powered up. The mechanisms are all frozen and a message appears on the screen saying "Table Error". I opened it up and cleaned carefully, but all I found was a disconnect wire at the front of the unit. Any suggestions? Thanks..
14,317
What happens when you reconnect the wire?
Do you have access to an oscilloscope to check the power supply voltages for signs of excessive ripple?
73's de Edd
Aug 21, 2015
3,730
Sir DKasey563 . . . . .
You say . . .
1 . . .CD player makes a loud hum when powered up.
2 . . . opened it up and cleaned carefully
3 . . . but all I found was a disconnect wire at the front of the unit.
I say now. . .
1 & 2 . . . Would / could that sound be coming from the audio / speaker, possibly relating to minimal / marginal power supply filtering
OR
Could that relate to a the sound of a motor continually running . . .
BECAUSE of a broken / str e e e e e e e tched / liquified belt.. . of which . . . . two are being used in that unit.
Therefore no mechanical action for completion of its functional cycle, such that the motor will then turn off.
3 . . .Why should it be normal for that unit to have a loose "war" / or / disconnected plug ? Identify that area . . . .
More finite details now . . . . .please . . . .
73's de Edd . . . . .
I've had such a frightfull day so far, that I think I'll just put an "Out of Order "
sticker on my forehead and just call it a day.
AlanG
Aug 31, 2024
My CDP-CX355 was not working, table error. I changed the belts and everything is working except after a CD loads but it does not spin. So, it does not play. I assume the motor that spins the CDs is not getting power but I can't tell from any of the diagrams where to power comes from.
