Sony CMT-SD1 Mini System - Failed display
I have recently aquired a Sony CMT-SD1 "Jewel" mini system which works
well with the exception that the display does not work. It seems a
beautifully made system which really does sound superb!. As the display
was not working when I got it, I am not sure if it is LCD or LED. Could
the problem be a simple bulb change (if it is LCD)- or new
board/display. I assume that if the display needs replacing, it may not
be cost effective! Any help or advice would ne appreciated. Please
email me direct on [email protected] - thanks Dave
A question in the group means an answer in the group. Why not open the
unit up and see if it has a lamp? It almost certainly has one, so once
you open it up, replace it as well.
Open the unit up and what do you see?
It is not like we can open it up over usenet.
Mark D. Zacharias
display was not working when I got it, I am not sure if it is LCD or
LED. Could the problem be a simple bulb change (if it is LCD)- or new
not be cost effective! Any help or advice would ne appreciated. Please
On some of these, even a lamp replacement is a major job.
Mark Z.
