Sony DAV-SA30 Power Supply
real_pixie
Hello Guys,
I have a Sony DAV-SA30 DVD surround system. It has been making a
ticking noise through the speakers so I thought I'd have a look inside..
I found that the power supply module, 1-687-086-15, is supplying
34.7volts on it's 27v output.
The 27v supply is high wattage to the amplifier card, it goes at follows:
+ from rectifier goes to the pin 1 of Q904, a 3 pin chip. Pin 2 of Q904
goes to the connector that supplies +27v to the amp. Pin 3 has a thin
PCB trace going to various surface mount components presumably to
control the voltage level.
I am trying to locate the fault but cannot identify Q904, it is labeled
PK K1189 33.
What do you think is my best bet for repair? Maybe a new voltage
regulator bypassing this Q904?
Any ideas gratefully received!
Kris.
F
Franc Zabkar
Hello Guys,
PK K1189 33.
2SK1189 MOSFET?
http://www.sanken-ele.co.jp/en/prod/semicon/pdf/2sk1189e.pdf
Check the drive to the gate of the MOSFET. Check for a D-S short
circuit.
Kris.
- Franc Zabkar
real_pixie
Franc said:
2SK1189 MOSFET?
circuit.
- Franc Zabkar
Thanks Franc,
I have removed the MOSFET from the board and tested the resistance
between pins, D-S is approx 1 ohm, which I understand would be correct
for a MOSFET, the gate pin has only 10 ohm resistance to both the D and
S. I think this may be the problem, I believe MOSFET G-D/S resistance
should be very high.
I'll get hold of a new MOSFET and give it a try. Do you think the 34v
going back through the gate will have damaged the drive circuitry?
Thanks for your help so far,
Kris.
F
Franc Zabkar
Thanks Franc,
Kris.
There should not be a D-S short in your MOSFET. Replace it and verify
that any other device attached to its gate has not been damaged.
- Franc Zabkar
