Sony mini-set PMC-DR45L line out questions
N
nitro2
I have a question about " line out " output .....................
This little unit has a front " line-out " , and a " l/r line out " on the
back.
The back connectores are used to connect the control-part to the
amplifier-part of this mini set ( thus connecting the 2 units together , the
amplifier is mounted in the second unit ) .
What i would like to have ( wishes ) is a second set of line-out connectors
to give this little unit the possibility to use it with a second-set of
powered speakers.
The real question is ;
-- Will it be possible to mount a second set of line-out connectors to the
excisting set on the back , ( and how ).
-- Second question , will the front mounted line-out cut-off the speakers
which are IN the unit ?? so this will be for the readers which own a unit
like this .
thanks for your advice
nitro2
N
nitro2
andrew,
I will try a y-cable
the other option i was thinking about ; car hifi high=> low converter
would that have been an option ???
nitro2
