Had a hectic weekend and didn't get a chance to work on the Sony until tonight.
Assembled the unit back together and set it up with the test lamp in place, switched the unit on and...
...success! The display now works and all functions can be selected via the front panel buttons!
And as you said 73's de Edd, the lamp initially comes on (not as brightly as previously), and then drops to a very dim glow.
As requested, I measured voltages as per the red/ black arrows and squares in the schematic shown a few posts back.
The red arrow reads approx 25v
The black arrow also reads approx 25v
The red and black squares were harder to find points on the board to put the DMM probes, as the access panel doesn't open in that area. However, it looked like they were the points coming from the full wave bridge rectifier (after passing through the two large capacitors). The full wave bridge rectifier pins were easier to probe, so I probed those directly. Here are the results:
+'ve pin = 51.4v
-'ve pin = -51.4v
Under the access panel there are also some voltage values printed onto the visible board. I probed these, and the DMM results more or less matched the values that were printed on the board.
Obviously without a proper fuse in place and with two power output transistors missing, I haven't hooked up the unit to an external sound input to see if it works with headphones or speakers. I assume before I do that I should replace the faulty power output transistors and the fuse first?
Either way, progress has been made and it appears that your diagnosis is 100% spot on 73's de Edd. Thank you for helping me get this far.
Are we done with testing, and should I now get some replacement power output transistors to replace those that were shorted? They're available online so I can get some ordered if that's the next step I need to take.
Hopefully I will be able to rescue this amp after all
Let's put the bridge rectifier back in . . .correct polarity . . . and leave the two bad POWER transistors out.
Then you can use the same protective series lamp, for permitting a non destructive power up testing.
Do just a 3 second power up to see if the lamp is BRIGHT . . .BAD . . .or just a medium glow and dimming.
If the latter, you can check the RED and BLACK SQUARE voltages to see if they are about the same value, since
we are operating on reduced voltage input now.
Also the RED and BLACK ARROW voltages, which should probably clear any suspicions of the Zener diodes that you tested earlier.
Get caught up on this and I will prepare a relevant schematic snippet of the audio output circuitry of the bad channel to see if some transistors that feed into the two bad power transistors might have also been crunched.
73's de Edd
+'ve pin = 51.4v
-'ve pin = -51.4v
