Sony (Sun) GDM20E20 Monitor - flashing standby but done boardswap
  • Thread starter System Alchemist
  • Start date
System Alchemist
Sony (Sun) GDM20E20 Monitor - flashing standby (1Hz 50% duty)
which I think means B+ problem.
However I have swapped all the boards (A, D and G)from a good
monitor into the duffo one and still get the same result.
This leaves the tube and the neck gubbins which is all soldered
and glued in place.
I don't have any schematics etc for this monitor (do you?!) or
any experience of repairing monitors.
Any ideas where to look with this one?
---Paul
CJT
and glued in place.
---Paul
If it's gone into protection mode, perhaps the CRT is drawing too much
current.
I doubt it's worth fixing, especially considering the price of working
used ones.
System Alchemist
current.
used ones.
I am happy to invest my time to avoid creating landfill prematurely if
this is fixable. The previous user found that a strategic nudge would
bring it to life but since transporting the monitor this no longer has
the desired effect. The monitor did work for about a week when I got
it.
---Paul
Andy Cuffe
it.
---Paul
Have you double checked that the horizontal and vertical sync are
getting to the monitor? Check the cable for opens. Also, I think
this monitor can't go below SVGA resolution without shutting down. If
this is the one with all the controls on a little IR remote, it won't
do VGA and DOS text modes.
Andy Cuffe
[email protected]
Jerry G.
This sounds like the CRT is pulling too much current. The CRT is not worth
replacing in these.
Jerry G.
and glued in place.
---Paul
System Alchemist
replacing in these.
Recently acquired info suggests that this may be:
Horizontal/Vertical deflection failure, thermal protector
Given that a board swap doesn't help, any suggestions what I should
poke (ideally with the monitor off) to narrow this down?
Any ideas on how the deflection failure is detected?
Likewise, what does the thermal protector protect?
TIA
---Paul
CJT
TIA
---Paul
I think they work a lot like the protection circuit on a Sony TV --
beam current (and potentially other parameters) are monitored and
if they exceed parameters trigger a signal that shuts down the
device.
