Sony VAIO (PCG-954A) DC Power Connector (plug)
msg
Does anyone have a description of the coaxial DC power connector
used on various Sony products such as the VAIO laptops (PCG-954A
is one of them) in order to find a source? These are the type
that often have a yellow insulator in the plug and a center pin
about 1mm in dia., however the O.D. is larger than the common
varieties used on much Canon gear. Perhaps this is Sony proprietary
but I am hoping there is a standard that permits second souring.
Michael
JANA
Sony is proprietary, you must order from Sony if you want something that
will reliably work!
JANA
_____
Michael
W
William Sommerwerck
Contrary to what JANA says, it's unlikely this is a proprietary Sony plug.
This type of "hermaphrodite" connector (it's both male and female) comes in
at least a dozen varieties of inside and outside diameters. Companies have
gradually switched to smaller plugs, probably because it eliminates the
possibility of an older, higher-voltage charger being attached to a device
that uses a newer, lower-voltage supply.
You might contact Sony customer service and ask. You might also measure the
plug (length, ID, OD) and start searching the online catalogs. You might
also call Sony Parts and ask to look it up.
There are lots of obvious options.
Sam Goldwasser
I expect you can find these on eBay as well, and probably a lot cheaper
than Sony.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
