Sound module
That one guy
Dec 23, 2016
17
For a project i need to be able to play a repeating sound clip at the push of a button and it needs to be loud enough as well.
I need to keep it cheap so i have decided to with a 3.7V battery and a 10W loudspeaker but i have no idea how to get a sound module. I wanted to change up a sound module in greeting cards but those require low voltage.
If you can please help me to figure out how to complete this project I would be extremely grateful.
Also if you have any ideas on how to make the sound output louder and make the circuit more efficient to make it cheaper please tell me.:)
Rayregula
Dec 20, 2016
84
Does it need to be under a certain size?
Look for audio amplifier module on Ebay.
You may have to go to a higher supply voltage for the 10w though.
That one guy
Dec 23, 2016
17
Tks for replying and the suggestions but those are a little to expensive for me i would like to keep it under $20 if possible, any ideas.
For the size, it can be a large but also to be handheld ( kind of like a shotgun ) I know it sounds shady but please bear with me :p
Audioguru
Sep 24, 2016
3,656
Powered by a 3.7V battery, an obsolete TDA2822M dual amplifier IC connected bridged to an 8 ohm speaker provduces only 0.3W which is less than a cheap clock radio.
Modern bridged audio amplifiers from Texas Instruments provide 0.6W into an 8 ohm speaker but the IC is so small that you can hardly see it and it will be impossible to solder.
That one guy
Dec 23, 2016
17
Again tks so much for the suggestions guys.
I think i figured out a way to use he greeting card sound module. By producing the sound using the sound module i can pick up the sound using another microphone, i can connect it to an audio circuit and amplifier, a battery and to a speaker. What do you guys think?
Audioguru
Sep 24, 2016
3,656
If the microphone can hear the speaker then you will have acoustical feedback howling.
Record it with the speaker turned off then play it back with the microphone turned off.
That one guy
Dec 23, 2016
17
so
but what if i soundproof the area between the mic and 1st speaker? Then the mic wont pick up the sound output of the second speaker right?
