Source for on-line volume control headphone extension pot
JeffM
Steve said:
I'd like to use an in-line volume control headphone extension
as a variable resistor for led brightness adjustment.
Your use of the terms "volume control" and "headphone"
just confuse the issue.
It is simple enough to make your own patch cords
with potted assemblies in the middle.
An example of the headphone extension :
http://www.ccrane.com/radios/radio-accessories/inline-volume-control.aspx
Is just the potentiometer available with its housing and thumbwheel
and is it available with linear taper ?
What you are trying to do doesn't sound like a standard application.
I don't think it is common enough that an off-the-shelf item exists.
A better description of what you are trying to accomplish might help
along with the number of units you will be producing.
I would need a resistance value of
somewhere between 1k and 10 k.
As that is a VERY broad range, it sounds like just a guess
--or did you derive it arithmetcally or empirically?
Do you actually have the LED(s) you plan to use in-hand?
Similar threads
Replies
5
2K
Victor Roberts
V
Replies
7
1K
Bob Ferapples
Replies
8
2K
Watson A.Name - \Watt Sun, the Dark Remover\
W
