Source of replacement for Relay for NAD C 326BEE
Nickelmore
Dec 5, 2020
6
Hello everyone,
I'm looking for a relay for my NAD C 326Bee amp, because the left speaker 'clicks' sometimes and the right speaker fails to run until a certain (louder) threshold of volume is reached
I would like to try to replace the relay and hope that it helps here.
I've found the relay in the service documentation:
RELAY POWER DC12V 8A/250V 2P1T
PCB MOUNT ME-11-012-2H4 (RoHS)
https://www.manualslib.com/manual/1441478/Nad-C-326bee.html
I couldn't find the same relay, but a documentation:
http://www.massuse-relay.com/details/ME-11.pdf
I also found that for example that the MASSUSE ME-11-012-2Z4 could be replaced with RELPOL RM84-2012-35-1012
(see: http://audiopurist.pl/en/articles-en/audio-relay-the-hidden-truth/)
But the contact form seem to differ: H vs Z. I couldn't find the difference here.
Which relay could I use as an alternative for the ME-11-012-2H4?
Thank you very much in advance!
Best regards
Dennis
14,317
Why do you think the relay is the culprit? Unless you hear the relay clicking on and off in synchrony with the speaker(s), the relay is very likely totally o.k.
According to the ordering information you linked:
2H4 = contact form 2A
2Z4 = contact form 2C
According to this info site the 2A is also known as n.o. (normally open) and the 2C is known as c.o. (change over). You should be able to use the 2C contacts if you cut the unused pins (green) as long as the remaining pins fit the hole pattern in the PCB.
Nickelmore
Dec 5, 2020
6
Hi Harald,
that's a good suggestion, thank you very much! I will check this one out!
Well actually the relay is a blind spot but my best guess so far, because it's one of the components which is faulty often.
First I've had problems with the balance potentiometer - I've bypassed it and it's much better now. But I've got still problems and I was able to narrow it down to the output amplifier of the amp (by testing another preamp and plugging in directly to the main in input and I've tested all other constellations with cables and speakers)
I know it's not much but I couldn't see any cold solder joints or capacitors on the board. The Relay is the blackbox for me right now. Maybe I will try to hear the clicking first - is this clicking 'loud' by any means?
Do you have any other components I might check too?
14,317
Before you buy a new relay, you can short-circuit the contacts of the existing relay with a piece of wire to verify that the relay really is to blame.
Grumi63
May 15, 2021
Hello, I have exactly the same issue.
Did the shortcut or the relay replacement solved your problem?
Thank you.
Nickelmore
Dec 5, 2020
6
Thank you.
Hello Grumi63,
I had 2 problems which I could solve differently:
1) the clicking on the left side. It was caused by the TV, via Aux and optical out. Another TV fixed that for me.
2) the dropping out of a speaker, until a certain threshold was reached: yes the new Relais helped!
I've implemented the following relais: (see picture). Works like a charm.
Grumi63
May 15, 2021
Great, my 'only' issue is the dropping out of a speaker, until a certain threshold.
I've just ordered the relay.
Thank you!
Brettergssicht
Oct 15, 2023
I Had the Same issue in the left channel. First i Changed the Balance Poti with No success. I ordered the relay on nickelmores picture. Changed Back the poti and Changed the relay. No Problem since about 2 Weeks. And it ist now also possible to listen to way more Low Volume as before. Thanks for the Infos.
Greetings
