Split HEX files..
JA
Hi guys!
Please i need support!
I have an hex file and i need to split it in low bytes and high bytes.
My eprom programmer just don't handle this function.I have to burn one low
bytes eprom and one high bytes eprom.
Can anyone help me splitting the file in high-low (i can send by email the
hex) or helping me finding a tool to do this?
Best Regards
AC
Jamie
JA said:
Hi guys!
Best Regards
AC
You mean its 16 bit data you're trying to partition ?
JA
Jamie said:
Now, if all you have is just a pure HEX file, that is an
easy one to do..
Do you have a file that I can look at ?
I have sended in your email the file!Thank you for the help!Let me know if
you receive it!
Jamie
JA said:
"Jamie"
Yes you got it!! exaclty this!
Ok, well, I don't know of any util that I have that
currently exist that can do that how ever, I am a programmer
and that seems to be a very simple task me
I assume these files have the address at the left column
and like 8 or 16 bytes of data per line ?
If this is the case, splitting the file would also mean
updating the addresses at the left..
easy one to do..
Jamie
you receive it!
Ok, I'll take a look at it.
Jamie
Dave said:
There's a freebie utility called SPLIT2.exe at
http://www.kmitl.ac.th/~kswichit/68k/SPLIT2.EXE. I think it will do what
you need. (It's DOS progran, but runs fine in Winders.)
I was going to suggest something like that, I did get the files he wants
me to convert. After taking a look at the Intel HEX format. I can do it
how ever, I suggested that maybe he'd try an existing tool first before
I whip up this GUI based app. :)
I've never had to split up HEX files before, other wise, i would have
already had a tool created :)
W
William Sommerwerck
Doesn't the programmer's manufacturer provide a utility to do this? You'd
think it would.
JA
think it would.
Some manufacturer will include this function! Dataman will do this, my
programming tool , doesn't let me do this!
Jamie
Have you successfully converted the files or do you still need help?
Rich Webb
It's not that hard to write, especially for a one-off use when you may
choose to dispense with the error checking that would otherwise expand
it in size by several times.
Regardless, you're not the first to need something like this. A nice set
of tools is available at http://srecord.sourceforge.net/ and there are
surely others out there with a bit of 'net searching.
F
Franc Zabkar
My Sunshine Expro-60 has a bunch of utilities that can do this.
http://www.danbbs.dk/~rmadrm/utility.htm
- Franc Zabkar
bz
you can do it with excel
there are bin hex and octal conversion functions such as bin2hex and hex2bin
there are parsing functions such as substr and mid
there is a concantination operator "&" that will allow you to paste the bytes
back together after swapping them.
Should be an easy program to write just using excel functions, but, if
necessary, you can dip into visual basic which is the macro language used by
excel.
