SPST LED Rocker Switch Wiring
Haelind
Jun 27, 2019
9
Need a little help with wiring this switch. I understand a 3 pin LED but this is a 4 pin. Looked for a wiring diagram but no luck only found a data sheet with dimensions and terminations. The power source will be 12v 10amp adapter.
Thank you kindly,
Haelind
14,317
Probably 2 pins (thin) for the light, 2 pins (fat) for power.
What is the part number?
Your photos 3 and 4 are hard to read - too much reflection. Try again, please, with good lighting, no reflections. The "print" may give the necessary hints if readable.
Audioguru
Sep 24, 2016
3,656
You do not step down to 2.2V. Instead you add a current-limiting resistor in series. The resistor will be (12V - 2.0V)/10mA= 1k ohms or use 510 ohms for brighter 20mA. A 1/4W resistor will be fine. Correct polarity of the LED is important.
14,317
The switch function is shown in the datasheet as follows:
and so is the LED connection:
