Square Wave Power Inverter and Magnetic Induction question
Lory
I got this 12 volts square wave power inverter. I heard
that if you put an LC passive filter in the output. It can
convert to sine wave. What is this LC passive filter
mean?? What value must I get? My inverter is 150 watts.
Another thing. My transformer is 12-0-12 to 110 volts.
What is the minimum frequency before the magnetic
field can no longer cause induction in the secondary??
For example. If the 12 volts ac runs at 3 Hz. Can
it induce the current at the secondary?
What is the explanation again why transformer can
induce current inbetween primary and secondary with
no physical contact between them? I mean.. I know
that if you rotate a magnet, it can induce current
in the wire around it. But in transformer, what's
the principle. Thanks.
Lory
