SSB Antenna for a Ketch
Doug Dotson
I believe that the ARRL patterns show the whip to be an unambiguously
better low-angle radiator than the backstay.
This might explain why I have had such good luck with a whip compared to
the backstay antenna I had on my previous boat.
But that's not all! The versatility of the backstay antenna at other
frequencies and the attendant complication of a tuner could be compared to
the simplicity of the whip, its physical independence from the mast, and
its lack of need for a tuner.
How do you get away without a tuner?
Doug
s/v Callista
Gary Schafer
Hello again, Gary. Thanks for your reply.
There are a few points still not settled. But first we need to separate
the objective importance of radiation at various vertical angles from
the objective reality of how much energy different antennas radiate at
these angles. There seems to be a reluctance among some in the group to
acknowledge that vertical radiation angles are important enough to
warrant an influence on antenna design decisions. I'm going to leave
that alone and just talk about how various antenna designs radiate.
They may be important but there is usually little you can do about it
on a boat.
My first "exhibit" is figures 54, 59, and 60 from the ARRL Antenna Book
(20th edition), Chapter 16. Vertical radiation patterns for a
quarter-wave, transom-mounted whip are compared with those for a typical
backstay antenna at 20 meters.
Figure 60 shows the backstay at 15 meters but there is no corresponding
quarter-wave whip figure for that frequency. Fortunately, however, we
are on fairly solid ground by assuming the vertical pattern of a
quarter-wave 15 meter whip will be quite similar to that of a
quarter-wave 20 meter whip. Thus, we can compare figure 54 to figure 60.
better low-angle radiator than the backstay. From these patterns, I can
easily imagine situations in which the backstay would nonetheless be a
better choice. I can just as easily imagine situations in which the
quarter-wave whip would be a better choice. Just based on the vertical
radiation patterns alone.
They only show the vertical angle at an azmuth of 90 degrees. Don't
know if that is the best or worse direction for the vertical angle.
If you look closely at those patterns you willl see that the backstay
vertical pattern is much broader than the whip. That is an advantage
when working various distances that require different take off angles.
Very low angles are usually only good for very long haul
communications. Want to talk to China or Japan?
Shorter range, around the US, usually require higher angles to do the
job.
Talk to some of the hams that have stacked beams on tall towers. Often
the lower antenna, with it's higher take off angle is superior to the
higher antenna on shorter paths.
Also remember that just because the maximum of the lobe may be at 30
degrees, dosn't mean that it is dead at 15 or even 10 degrees. It may
only be down a couple of db at lower angles.
to the simplicity of the whip, its physical independence from the mast,
and its lack of need for a tuner. These are other considerations that
might affect one's choice. Heck, they're not even mutually exclusive!
Just measurably different.
A whip with no tuner is good for only one frequency. And then it
requires some sort of matching network to make it work. Might just as
well put in a tuner and make use of it on other frequencies too.
Regarding the alleged necessity of a vertical antenna for "surface wave
type communications," please consider the US Marine Corps' take on this
in their Antenna Handbook (MC RP 3-40.3C, page 4-40):
"NVIS propagation is simply sky wave propagation that uses antennas
with high-angle radiation and low operating frequencies. Just as
the proper selection of antennas can increase the reliability of a
long- range circuit, short-range communications also require proper
antenna selection. NVIS propagation is one more weapon in the
communicator’s arsenal.
To communicate over the horizon to an amphibious ship on the
move, or to a station 100 to 300 kilometers away, the operators
should use NVIS propagation. The ship’s low take-off angle
antenna is designed for medium and long-range communications.
When the ship’s antenna is used, a skip zone is formed. This skip
zone is the area between the maximum ground wave distance and
the shortest sky wave distance where no communications are possible.
Depending on operating frequencies, antennas, and propagation
conditions, this skip zone can start at roughly 20 to 30 kilometers
and extend out to several hundred kilometers, preventing communications
with the desired station.
NVIS propagation uses high take-off angle (60° to 90°) antennas to
radiate the signal almost straight up. The signal is then reflected
from the ionosphere and returns to Earth in a circular pattern all
around the transmitter. Because of the near-vertical radiation angle,
there is no skip zone. Communications are continuous out to several
hundred kilometers from the transmitter. The nearly vertical angle
of radiation also means that lower frequencies must be used. Generally,
NVIS propagation uses frequencies up to 8 MHz."
Sorry for the poor formatting. NVIS is what you get with a horizontal
dipole on the deck of a non-metal hull that I had mentioned. I really
doubt that you can get reliable daytime 3 MHz communication using 150
watt transmitters and antennas connected to 50 foot masts and at
distances of hundreds of kilometers. But with NVIS, it is routine.
The "surface wave" propagation that I was talking about, that requires
vertical polarization, is not the same thing. NVIS is still dependent
on ionosphere reflections and is at the mercey of the ionosphere.
Daytime may kill the signal.
With surface wave propagation it is there all the time, night or day.
It is what broadcast stations depend on. It is very usefull on the 2
mhz marine band with proper antennas. The signal follows the surface
of the earth rather than being reflected from the ionosphere.
The other point has to do with the vertical radiation pattern of a
3/4-wave vertical. You will agree, I believe, that the VERTICAL pattern
of the 3/4-wave vertical over perfect ground is "one-half" of the
HORIZONTAL pattern of a 1.5 wavelength dipole in free space. (Split the
dipole with a plane perpendicular to the wire's axis and then rotate the
plane through 90 degrees so the wire is vertical. You can throw away the
image beneath the plane to make it look like the usual patterns.) It
follows, then, that the lobe of the 3/4 wave antenna in the vertical
plane will peak at 45 degrees. Of course, over real ground the pattern
will be different. I doubt though that real ground will LOWER the
vertical radiation pattern. In any case, my statement has nothing to do
with the the height of a horizontal dipole above ground.
No, you can not just split the pattern of a horizontal antenna and
rotate it to get a vertical pattern. In free space yes, on the ground
no. The earth has a large effect on it. Reflections from the earth add
and subtract to determine the pattern.
If you look at the vertical patterns from a horizontal antenna at
different heights above ground you will see drastic changes in the
vertical pattern.
There is not a lot of information printed on vertical radiators of
different lengths. Folks often confuse the horizontal patterns with
what a vertical pattern would be.
As an "exhibit" on this point, I offer a meager quote from Low Band
DXing (3rd edition), page 9-51:
Note that going from a 1/4 wave vertical to a
1/2 wave vertical drops the radiation angle from
26 degrees to 21 degrees. More important, however,
is that the 3-dB vertical beamwidth drops from 42
degrees to 29 degrees. Going to a 5/8 vertical drops
the radiation angle to 15 degrees with a 3-dB beamwidth
of only 23 degrees. But notice the high-angle lobe
showing up with the 5/8 wave vertical. If we make the
vertical still longer, the low-angle lobe will disappear
and be replaced by a high-angle lobe. A 3/4 wave vertical
has a radiation angle of 45 degrees.
So the humble contribution I've been trying to make is that longer
antennas are not always better than shorter ones. They are sometimes
better and sometimes worse. But they are always different. Whether the
difference is worth considering pretty much depends on the nature of the
difference.
I agree. Large ships usually have several different types of
antennas. However, in most boat installations you usually only have
one shot at it. One antenna is all there is room for. I would opt for
as much wire as I could get up in that case. More wire will give much
improved performance on the low bands with a moderate compromise on
the high bands.
Doug Dotson
A 50' to 75' whip on any boat would be a problem. A backstay
is not a whip.
Doug Dotson
Comments below.
Chuck said:
Doug, it's difficult to generalize but in many cases the radiation
resistance of a whip will be in the range of 20 to 35 ohms (assuming the
whip is a quarter-wave or somewhat shorter) and the ground resistance in
series with that may be another 25 ohms or so. What you get is a feedpoint
impedance of about 45 to 60 ohms (could be more or less) which will match
50 ohm coax very nicely without a tuner. Most transmitters will feed loads
of 25 to 100 ohms (2:1 swr) without complaining. For a short run of coax,
your total losses will probably be less than if you used a tuner.
Agreed.
It is true that you can only use such an antenna for a single marine or
ham band.
And as such is an inconvenient situation on a boat.
Even then, at the lower frequencies, you will experience a limited band of
frequencies that you can use without a tuner. On 8 MHz and above, you will
probably find that an antenna cut for the middle of the band will cover the
whole band nicely.
SOP for single band antennas unless one is interested in only a subsection
of the band in which case one cuts it for the center of the segment of
interest.
A lot of cruisers keep a 14 MHz "Hamstick" on board as an emergency
antenna they can use if their tuner fails or if (heaven forbid) they are
dis-masted and can't use their backstay antenna.
I have Hamsticks for 80, 40, 20, and 15M. They were my only antennas
for a long time before I insulated the backstay and got an SGC auto
tuner. I still hang on to the Hamsticks as backups though. When I got
another boat that already had a 23' whip, I found that it worked better
than the backstay on my previous boat, so I have stuck with it.
In an emergency you can check in to the Maritime Mobile Service Net on
14.300 MHz even if you're not a ham. It is one of the few frequencies
monitored almost continuously by experienced operators.
I have been checking into the MMSN for years now. Actually, the MMSN
is only in operation during certain hours (1200 to 2000 Eastern time). Other
nets are in operation during other hours (Coast Guard Net, InterCon, etc) In
an emergency you can check into anything anywhere.
The Hamstick is easy to store, easy to install, and once adjusted, should
be trouble-free. To switch bands, you switch Hamsticks. They even make a
quick-connect gizmo.
Been using them for years.
There are other makes as well. But if you don't use something like a
Hamstick, and just use a longer whip like a 16 foot whip, it will be good
for just one band. Actually, 16 feet is close to a quarter-wave on 20
meters so you may be able to use it as-is without a tuner on that band. If
you're not comfortable doing the hookup, find a local ham to advise you.
They're usually glad to help.
I am a local ham :) I help myself alot :)
Good luck!
Thanks!
Doug, k3qt
s/v Callista
Doug Dotson
I supose that one could make a trap-vertical to avoid a tuner, but
I've never seen one for marine bands. I do recall a version of the
OutBacker that was for marine use but have never known anyone
that had one.
Doug, k3qt
s/v Callista
Doug Dotson
I believe that is what my whip is. Although I'm not sure that it is
wound around the pole though. It is made by Shakepeare.
Doug
Bruce in Alaska
is not a whip.
Doug, what I was talking about was a backstay that feed a whip side
mounted to the top of the mast. that way a 35' backstay feeding a 28'
whip would be 60+ft electrical antenna.
Bruce in alaska
Bruce in Alaska
Doug
Nope, Helical wound antennas exist but Shakespear doesn't make them.
At least not the ones that I am familiar with.
Bruce in alaska
Bruce in Alaska
that had one.
Doug, k3qt
s/v Callista
Morad Electronics of Seattle has been making Trapped Verticles for
4-22Mhz for years. They were pioneered by Ed Zanbergen back in
the late 60's, and have been a fixture in the North Pacific Commercial
Fleet ever since.
Bruce in alaska
Doug Dotson
Oh, I see. I barely fit under the 65' bridges much of the time. Even twang
the VHF antenna on occation. Don;t think that solution would work
well for me.
Doug
s/v Callista
Doug Dotson
But are the traps tuned for the marine bands? I've had many trap
verticals for ham bands and trap dipoles as well.
Doug, k3qt
s/v Callista
Doug Dotson
SOunds like a step up since there are no fiberglass trap verticals
for recreational boats as far as I can tell.
Doug, k3qt
s/v Callista
Bruce in Alaska
Doug, k3qt
s/v Callista
Oh yea, they are specific for the Marine Bands. These were designed
specifically for use on Maritime Mobile Frequencies in the HF range.
While Eddie Zanbergen was alive, he was one of the worlds formost
Marine Antenna System Designers. He also build special versions
of most of his popular Marine Antennas, for the Ham market as well,
but most hams wouldn't pay the price for a commercial grade antenna,
so they were custom built on demand. I have a bunch of these special
antennas, that Ed built for me, that I have never had a place to install,
but when I finish my Retirement House, they will all be part of the
antenna array that goes along with that project. Morad still makes
the VHF-HD10db Base Stataion Antenna in both Marine and Ham versions.
This antenna is the STANDARD throught the North Pacific for Coast
Stations and Vessels over 60 Ft. You will not find any other antenna
on 99% of the Bering Sea Crab Fleet, as they need the MOST Rugged,
and Weather Resistant Antenna available. This one is the REAL DEAL.
I have seen Super Station Masters, twisted up like a Pretzel and a
Morad still standing on the same tower, after a 130 Kt wind storm.
Bruce in alaska
Similar threads
W
Replies
7
3K
Larry
Replies
9
2K
Gary Schafer
Replies
18
4K
Lynn Coffelt
Replies
116
10K
Bruce in Alaska
