starfire
- Jan 1, 1970
- 0
Hi all -
I'm working on a project that requires a stable, repeatable integration of a
35ms, 4.1VDC pulse input to produce a negative-going ramp output.
I've constructed an integrator using an LF347 quad, JFET input, op-amp with
a 0.01uF cap in the feedback (output to negative input) and a 1.82Mohm input
resistor into the negative input. I've also tied a 1.82Mohm resistor to
ground from the non-inverting input. The source signal is a negative-going,
TTL pulse so I ran it into the gate of an N-channel MOSFET. The source of
the MOSFET is grounded and the drain is pulled up to a regulated 4.1VDC
supply through a 100K resistor. The "on" resistance of the MOSFET is about
5 ohms (2N7000). I tapped the drain of the MOSFET into the positive input
of one stage of the LF347 set up as a voltage follower. The output of the
voltage follower drives the input resistor to the integrator. The output of
the integrator goes to another voltage follower and a 10K resistor to
ground. I'm using 1% carbon resistors and a 10% polyester capacitor.
The circuit will be used to generate multiple consecutive ramps, so an input
reset signal is received prior to the pulse associated with the ramp. This
reset will be used to enable an analog switch or a MOSFET to discharge the
capacitor in a short period prior to starting the ramp.
The circuit needs to be very linear and repeatable.
Is there something I can add to this circuit to make it more stable and
repeatable?
What will be some of the major points to be concerned with for reducing
noise?
Does this sound like a viable approach or is there a better way?
Thanks for any constuctive input.
repeatable?
noise?
