I need some help in making Good power stability circuit
aman00007
Oct 14, 2025
I have one lora rfm95w one atmega644p and one rtc and my battery voltage is 8v for atmega 644 need 5v rtc need 5v and lora rfm 95w need 3.3v how I make good circuit so that less power consumption and industrial grade pls help me for making my circuit
danadak
Feb 19, 2021
1,096
If you are not totally focused on power savings just use two 3 terminal regulators
for the correct voltages needed.
If power conscious use dual switching regulator where 5V comes from switcher
and its internal LDO used to gen the 3.3V
Just an example (this has to be designed for your 8V input) : https://www.analog.com/media/en/technical-documentation/data-sheets/3645f.pdf
Note you can always use just a single buck and an external LDO to do same thing.
Probably cheaper than above example.
Or in simplest form use 2 zener diode shunt regulators, but they waste a lot of power.
Taj bartlem
Aug 7, 2025
10
DC-DC buck convertor, Zener diode, open loop regulator, closed loop regulator or 3 pin voltage regulators(78** and 79**)
14,299
Ready to use step-down switching regulators are readily available from many (Asian) vendors.
There are also plug-in replacements for teh venerable 7805 regulators using swithc-mode technology, although these tend to be more expensive than the cheap modules from Asia.
