Ldanielrosa1
- Nov 25, 2003
- 316
- Joined
- Nov 25, 2003
- Messages
- 316
I'm working on a house that needs nearly everything brought up to code. While the walls were open, I put in enough media drops to run an arcade (30 ethernet points, assuming I don't start using the 'phone lines too). I gave it some thought, and decided not to include any heavy wire- so no speakers without a remote amplifier.
Anyway, the distance is moderate so the wire resistance may be as high as 2 ohms from the distribution point to the farthest box. This could be highly undesirable if I wanted to power something through the signal wires, however...
The query is this: Has anyone encountered anything whereby a moderate impedance, moderate negative voltage (-12 => Vsource => -48) goes through a switcher to provide a low voltage (=> -1V) for an alternate current path to keep ground stable? Does this make sense to anyone else, or am I babbling out my navel?
