Step Down transformers, will they harm an electronic machine?
Muntaser
Oct 23, 2022
7
Hey everyone, before saying anything I'm like very newbie when it comes to electronics so please have patience on me :p
so here's the deal, I'm currently living in Palestine where we are using 240V outputs. I'm planning to buy a coffee maker from Amazon, unluckily that coffee maker I'm interested in is using 120V . So I was wondering if step down transformers can by any chance harm the machine?
this is part of the reply the coffee maker company sent me
"It is not recommended to use a transformer or voltage converter for this unit, as it could still potentially damage its motor base. However, please keep in mind that we work very hard in order to make sure that as many customers as possible get to try and enjoy our units. We appreciate your understanding."
btw the machine company is known as "NinjaKitchen"
Thanks in advance for helps and advices
bertus
3,877
The problem could be in the 50 Hz and 60 Hz difference.
Bertus
bertus
3,877
No, a stepdown or stepup transformer can not change the frequency.
Bertus
Muntaser
Oct 23, 2022
7
Bertus
hey
Is there a way to tackle that issue? since the product will most likely be assigned for a 60hz while we have a frequency of 50hz
Minder
Apr 24, 2015
3,561
I can't see a coffee maker being all that sensitive to Hz.
Also don't see a "motor" referenced in the product! (Coffee maker)
Muntaser
Oct 23, 2022
7
but wouldn't using a machine that is designed for a 60 hz on a 50 hz get damaged and ruined?
Minder
Apr 24, 2015
3,561
Not necessarily, I don't see anything frequency sensitive, in a coffee maker especially!
kellys_eye
Jun 25, 2010
6,512
Note that, depending on the power consumption of the coffee maker, the step down transformer (regardless of the frequency) may cost more than the coffee maker.
kellys_eye
Jun 25, 2010
6,512
Wow! 1500W
You're looking at ~$120 for the transformer to run it. I doubt the 50/60Hz will make much difference but since the manufacturers have advised against it (sort of) they would certainly use this as an excuse to refuse to honour any warranty issues.
That's as much as we can reliably say on the matter - it's your money!
Externet
Aug 24, 2009
944
Cannot believe there is no coffee makers in Palestine stores other than the Amazon choice.:oops:
Muntaser
Oct 23, 2022
7
hahahha there's plenty of them ! the model I'm looking for has a lot of functions that's why I'm interested in it
so it makes coffee.....and then it makes more coffee.
Mind boggles as to what other functions one would want in a coffee maker.
Then again, there are mobile phones that mostly do everything but make a phone call when one needs to.
And yuppies pay thousands for the privilege.
Alec_t
Jul 7, 2015
3,821
I'm with Bluejets. What functions does a coffee/tea maker need, other than time and temperature control for the brew, and a couple of on/off switches for the heater and frother?
Martaine2005
May 12, 2015
5,318
Buy a secondhand power tool 110V transformer. I see them all the time between £20 and £50.
Martin
