Stepper Motor voltage allowable?
eem2am
Aug 3, 2009
429
I have this stepper motor which i intend to drive with 36V even though its only 6V rated................
("UBB1", Rated Voltage = 6V, 18.5Ohms per phase)
http://www.auf-vertrieb.business.t-online.de/pdf/UBB.pdf
....how can you tell what is the maximum allowable drive voltage for this (above) stepper motor...or indeed, for any stepper motor?
You're making a smoke machine, right?
Easy, read the spec sheet.
In this case it says 6V.
The only way you might get away with 36V is to use PWM with a max "on" time of around 15%. Even then, I'm not sure it would be my fiirst choice.
Resqueline
Jul 31, 2009
2,848
For static purposes a voltage rating is fine, but for dynamic high-speed use one should consider using the current rating instead.
A stepper has a considerable inductance and so it takes a while for the current to rise after a voltage step. It is the current that drives the motor to a new position.
So to make the motor run real fast one needs to use a higher voltage than rated power supply and drive the motor with a constant current instead.
Using a (constant current) PWM scheme will be neccessary to avoid having a large power dissipation in the driver.
One may also need to know if the rating is for full-step use only or if it can take half-stepping too (which increases the average motor dissipation by 50%).
