audioguru2
- Apr 6, 2004
- 12,022
- Joined
- Apr 6, 2004
- Messages
- 12,022
Does the microphone pickup music?faizanbrohi said:Everthing is working fine but there is one problem the Attenuation is still low . i can still hear music when the pot is fully turned off , i think a higher value potentiometer would solve the problem , a 200K or 300K Pot should solve the problem , well i am going to check it in my university because they have big high wattage pots , seems that they should work fine .
Does the amplifier also have an input selector switch and a line-level input for music that needs a shielded audio cable?
When the pot is turned down, the power amp shouldn't have an input. Maybe the pot is defective and doesn't go down to zero.
A higher resistance or high power rating won't make any difference.
The cause depends on whether the hum is reduced when the volume control is turned down, then the input wiring or preamp's power supply filtering are to blame.and one more thing when not playing any sound or music there is a very annoying hum , how to stop this ??
1) Use very short wires from the electret mic to the input of the preamp, or use a shielded audio cable.
2) Add a grounded metal enclosure for the preamp.
3) Use better filtering of the power supply for the preamp.
4) Keep high current pcb tracks away from the preamp.
