stuck between the problem
bhuvanesh
Aug 29, 2013
201
question : find intrinsic carrier concentration at T=200k for silicon (in cm^-3).
Answer is attached.In that why is that (200/300)^3 is added there.my only hope is this forum.Thank you
Arouse1973
Adam
Dec 18, 2013
5,178
Are you seriously trying to teach yourself semiconductor physics?
Adam
Ratch
Mar 10, 2013
1,102
Nc and Nv have temperature parameters that are raised to the 3/2 power. If the temperature ratios are moved outside the exponent brackets, then the temperature ratios have to be raised to the third power to compensate for the move.
Ratch
bhuvanesh
Aug 29, 2013
201
Why we need to move temperature outside the exponential.i have solved this in my way say weather it is right or wrong with explanation .Thank you
Ratch
Mar 10, 2013
1,102
Nv and Nc have their temperature parameters inside a term raised to the 3/2 power. You don't need to take those temperatures outside the radical, but if you do, you have to compensate for their removal. The solution seems to have elected to move the temperature parameter to the outside the radical. Therefore, the temperature term has to be raised to the third power to compensate for the movement.
Ratch
bhuvanesh
Aug 29, 2013
201
sire i dont understand what do you saying here ,where it is raised to 3/2.its raised to power 3.
Ratch
Mar 10, 2013
1,102
What book are you using? Doesn't it have the formula shown in the attachment? When Nv and Nc are multiplied together, the "2" in the denominator is cancelled and "3" remains.
