stun glove
audioguru2
Apr 6, 2004
12,026
Ridiculous.
A little 9V battery will supply only about 200mA to the circuit and its voltage will drop to about 6V. The 6V at 200mA is stepped-up by the transformer and 100 voltage multiplier stages to 12kV at only 100uA if it works perfectly without any loss.
Your schematic shows an output of 30kV at 8A. That's 240kW!
A little 9V battery can supply only 1.2W, and most will be used to heat the circuit so nothing will be left for an output.
ZAP101
Dec 6, 2005
53
I think its .8 A, and that probably isnt acurate either...NOW AUDIO YOU SAY THIS CIRCUIT PRODUCES NO OUTPUT :( well then build it and then test the output on yourself...IT PRODUCES ONE HELL OF A "NO OUTPUT" :p
audioguru2
Apr 6, 2004
12,026
If it was rated at 0.8A then it would say so. Your schematic says 8A.
Did you use a little 9V battery? It hardly has any current. It has tiny AAAA cells inside.
Did you build 100 voltage multiplier stages? Each stage divides the current. Nearly no current divided by 100 equals nothing. 12kV might make a little spark, like a piezo lighter.
live or die
Jun 14, 2006
can any one give me exact instructions on how to make a stun glove? ive been searching all thru the web on how to make one but had'nt had any luck except for info society helped but i still need further instructions on how to make it step by step. it would help me alot. THANK YOU.....
