Well, Kevin, since millions of people use wrist straps with series resistors in the belief that the resistor will protect them from injury resulting from accidental contact with line voltage while wearing the strap, can you provide a little more fact-based analysis of why the protection is not effective, or at least beneficial enough to be used? That is, do you believe that the possible currents are above injury or fatality levels, or what? What alternative do you suggest for static protection?
By the way, I'm not clear that we are talking about the same hazard when you say, "A wrist strap will not protect anybody from the AC outlet." The WRIST STRAP is not intended to protect the wearer from the AC outlet. The wrist strap is only to protect static sensitive euipment you are working on from discharge of the static electricity buildup on the body by continuously draining off the charge to ground. The RESISTOR in the lead to the wrist strap is to limit currents that could flow through the body in case of accidental contact with the line to low enough values that injury or death is avoided. Please explain why this is not protective.
Please don't be insulted about this effort at clarification. You never know what experience level you are communicating with out there in the forums.
Thanks.
awright
