substitute 4558 op amp for guitar compressor?
scorp
Nov 29, 2013
18
It's there a replacement for it? I'm uploading the schematic.
14,487
the 4558 is readily available, why do you want to sub it ?
scorp
Nov 29, 2013
18
Also, would the pots be audio taper or linear taper?
Found the answer to this..
14,487
see if radio shack have 1458 its the same chip different manufacturer
DAve
scorp
Nov 29, 2013
18
The best kid I've built are ones that explain how the circuit worked. Since this circuit is not in kit form, can someone please explain how it works?
Thanks for your time
Jeff
duke37
Jan 9, 2011
5,364
Starting at the op-amp, this has a gain of 23. The output is rectified and smoothed to give a positive feedback voltage.
The feed back voltage is fed to the second fet which is turned on when the gate is less negative. This shorts the signal to ground. So, the larger the signal, the more the attenuation. giving a more constant output.
The first fet is there to adjust the effectiveness of fet2
scorp
Nov 29, 2013
18
Thank you
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
They're not the same. The main difference is the GBP (gain-bandwidth product) but this varies significantly between manufacturers. A clear example is STMicroelectronics, who manufacture both types. Their 4558 has a GBP three times higher than their 1458.
I think, from memory, that the 1458 is a dual 741. The 4558 is a newer design. It's also newer than the LM358, I think, which is probably the commonest pin-compatible device, but also has the lowest GBP.
In this circuit you might not notice the difference, since the gain is only 23.
14,487
yeah i was kinda hoping it would do OK :)
gosh I have dozens of 4558's here, use them in several commercial products I produce
he must be able to find someone in his country that sells them in small numbers
