Grant
- Jan 1, 1970
- 0
Hi there
I've built a one amp current sink and at present it is uncompensated
and it is performing quite nicely as a 200kHz power oscillator, with
about 2V p-p across the 2.579 Ohm compound current sense resistor.
Following text is based a screen scraping of a web page I just put
up, along with some pictures to describe this issue at:
http://grrr.id.au/current-sink/
I've not done much with MOSFETs in linear amplifier mode, so some
suggestions for stabilising this one Amp current sink circuit are
needed.
The circuit uses an N-channel MOSFET for the pass element, a 0.5%
accurate TL431B reference and a couple dozen 0.1% resistors provide
for accurate current sensing with a 2.579 Ohm shunt.
The circuit 'works' in the sense that the magic smoke stays where
it belongs and no components get overly warm. The circuit needs
stabilising as the thing is at present uncompensated and oscillating
around 200kHz.
The circuit diagram:
http://grrr.id.au/current-sink/CurrentSink-circuit-750x736.jpg
Circuit description: Fixed 1.000 Amp current sink. Of that one Amp,
983mA goes through the current sense resistor, the remaining 17mA
current goes via a trimpot scaling circuit to feed the TL431B's
Ref pin. A 13V zener limits gate drive voltage during circuit
saturation, and a 110 Ohm gate resistor is placed close to the
MOSFET.
A bank of 24 by 61R9, 250mW, 0.1% resistors to form R9, a 2.579
Ohm, six Watt current sense resistor. Calibrating the current
sink to 1.000A is done by adjusting the trimpot to so that 2.535V
is measured across the current sense resistor, with a 4 1/2 digit
Fluke multimeter.
Photo of the oscillation waveform:
http://grrr.id.au/current-sink/CurrentSink-waveform-R9.jpg
The oscillation waveform shows about 2V p-p across the 2.579 Ohm
current sense resistor. The MOSFET is happy enough on its large
heatsink, it gets very warm to the touch but it's not too hot
for continuous operation.
Photo of the built circuit:
http://grrr.id.au/current-sink/CurrentSink-photo.jpg
Photo of the thing shows placement of the MOSFET gate resistor
up close to the MOSFET gate where it belongs. The large heatsink
allows continuous operation, as the input voltage may go up
to 30V, from the nominal 24V.
What's needed are suggestions for what stabilising components
to use around the TL431B. Circuit frequency response is not
that critical as this current sink will be used to measure
the value of compound power resistors up to about ten Ohms,
while trimming their value.
The circuit is powered from a 12 cell 40AH or 100AH SLA battery.
Web page is here: http://grrr.id.au/current-sink/ where I'll add
further information as I play with the thing, and as ideas you
contribute are added.
Grant.
needed.
around 200kHz.
MOSFET.
Fluke multimeter.
Grant.
