summing amplifier with linear offset
dB
The
Use a potential divider and pot to get your 0V to 1.6V. Buffer the
voltage from the pot's slider with a unity gain follower (e.g. OP07).
Connect its output to the summing amp through an R equal in value to
the feedback R.
?ine Canby
Hi all,
Thanks very much for your advice; this is the circuit I've designed ->
http://www.geocities.com/aine_canby/atten.gif
The 15 volt rails are from a regulated source. I wasn't sure about
what resistance to choose for Remit, does 1k sound OK? I also haven't
buffered the AC signal, again does that sound reasonable?
I'm now getting a linear response when the POT (1K) is adjusted, from
about 0 Volts to 1.411 Volts at the output, which I'm happy with.
The output from my circuit will be used to drive a constant current
driver. This driver converts an input voltage to a current. I need to
ensure that I only apply between 0 Volts and 1.6Volts to this driver,
otherwise I will get a current which will damage the equipment I'm
driving. Is there such a this as a 1.5 or 1.6 Volt Zener? Any other
suggestions with regard to this issue?
Thanks again for your help,
Aine.
Ann Canby
I sorry in advance if I've double posted.
Hi all,
about 0 Volts to 1.411 Volts, which I'm happy with.
Aine.
F
Fred Bloggs
Hi all,
Aine.
Yes- you can use what is called a "clipper"- like so-you can use an
LM324 quad:
Please view in a fixed-width font such as Courier.
+15
| 4.7k
+--|-\ | | > -+-->Vout
Vin >-------------|+/ 1N4148| |/
from |/| |
summer -15 |
| +15 |
1.6VDC >----------|+/ 1N4148
LIMIT |/|
-15
F
Fred Bloggs
LM324 quad:
+15
| 4.7k
from |/| |
summer -15 |
| +15 |
LIMIT |/|
-15
Cascade a second clipper to keep Vout>=0V like so:
+15
| 4.7k
| |\| | +-|-\ | | >-+>Vout
| >--|<|---+----|+/ 4148| |/
Vin >-------------|+/ 1N4148| |/ |
from |/| | /
summer -15 | 1k
| +15 | ///
LIMIT |/|
-15
