Summing Amplifier with non-ideal op-amp
Spehro Pefhany
I read in sci.electronics.design that Spehro Pefhany <speffSNIP@interlog
Sorry, where does 1/(N+1) come from? This 'open loop signal' is due to
the op-amp open loop gain not being infinite?
Assume all the N summing inputs save one and the output of the op-amp
are grounded (the op-amp is doing nothing). With a voltage Vin applied
to the remaining summing input, the voltage at the inverting op-amp
input is Vin* 1/(N+1). That effectively degrades the Vos, GBW, DC gain
characteristics of the op-amp by a factor of ~1/(N+1). Or to look at
it from another direction, you have a passive ~1/N attenuator followed
by a non-ideal amplifier with gain ~-N (N>>1).
Best regards,
Spehro Pefhany
Jim Thompson
Best regards,
Spehro Pefhany
Eh? Does this "summing" amplifier not include a feedback resistor?
If there IS a feedback resistor, the OpAmp maintains a virtual ground
at the inverting input, so the gain is simply Rf/Rin.
The unused inputs have no effect on the gain... HOWEVER, they do add
_offset_voltage_ terms.
...Jim Thompson
John Woodgate
I think we are discussing different configurations. I presume a feedback
resistor R, and N individual series input resistors, also R. The output
is definitely NOT grounded; it has voltage V appearing on it. The
voltage at the inverting input is zero for an ideal op-amp and is V/Ao
for an open loop gain of Ao.
Spehro Pefhany
When you close the loop, yes.
Yes, -Rf/Rin, with an ideal input. Or -1 for a gain-of-one summing
amplifier from a given input to the output.
But shunt that virtual ground to ground through a relatively low-value
resistor and you degrade the performance. That's effectively what we
have here.
...Jim Thompson
I think they do affect the non-ideal gain (and GBW) as measured from a
single input to the output with the other inputs at 0V.
Best regards,
Spehro Pefhany
add _offset_voltage_ terms.
So the lower the parallel equivalent to ground (unused inputs) the
higher the offset voltage... but the noise increases or decreases?
John Popelish
Make that nearly a virtual ground. It is only an actual virtual
ground with an infinite gain amplifier.
So, when there is finite gain, there is some small voltage (output
voltage over open loop gain) at the - input that drives the output,
and that small voltage also drives some of the input current through
the other input resistors. When the effective parallel resistance of
all the other input resistors is so low that it soaks up half of the
total input current (from the one input in question), there will be
only half of the input current to go through the feedback resistor,
and so the gain will have fallen to half.
Jim Thompson
have here.
Best regards,
Spehro Pefhany
So the "Rin" are very small?
Time to write some equations and impress the students ;-)
...Jim Thompson
John Woodgate
I read in sci.electronics.design that John Popelish <[email protected]>
wrote (in said:
Make that nearly a virtual ground. It is only an actual virtual ground
with an infinite gain amplifier. So, when there is finite gain, there is
some small voltage (output voltage over open loop gain) at the - input
that drives the output, and that small voltage also drives some of the
input current through the other input resistors. When the effective
parallel resistance of all the other input resistors is so low that it
soaks up half of the total input current (from the one input in
question), there will be only half of the input current to go through
the feedback resistor, and so the gain will have fallen to half.
The resistance looking into the virtual ground is R/Ao. Since Ao is sort
of big, you need an awful lot of grounded inputs to get to a shunt
resistance equal to that! OK, if you are pushing a 741 op-amp to 20 kHz,
there is a problem, but who does that these days .....? (;-)
Jim Thompson
The point is that with any opamp, the effective bandwidth starts
dropping when you shunt the input to ground. So the question of how
many inputs you can have (actually how low a shunt resistance you can
tolerate) must include the gain bandwidth required, as well as the
opamp in question.
See.......
Newsgroups: alt.binaries.schematics.electronic
Subject: Re: SED: Summing Amplifier with non-ideal op-amp -
GBWwithMultipleInputs.pdf
Message-ID: <[email protected]>
...Jim Thompson
John Popelish
opamp in question.
Larry Brasfield
I can remember designing a number of op-amp circuits
where loop gain was a concern, some fairly recently.
Of course, the frequency at which loop gain became
a concern was higher than 20 kHz.
In any configuration where loop gain is needed to get
accuracy (which includes driving down the natural,
open-loop distortion of the amplifier), and where
adequate loop gain is not a foregone conclusion, if you
add inputs then you have likely degraded loop gain and
need to reevaluate its adequacy. This can happen in
real situations; you should not defer that kind of analysis
for (nominally) unity gain DC summers with hundreds of
thousands of inputs.
In an earlier post on this subthread, you wrote: "The
and is V/Ao for an open loop gain of Ao." Very true,
but if you look at the named subject, and consider the
formula for closed-loop gain (which I posted earlier):
Avcl = G / (1 + GH) == 1 / (1/G + H)
you should be able to see what happens as H (which
designates the gain of the feedback network) is made
so small that it approaches 1/G. The closed loop gain
is no longer well approximated as 1/H, which is the
result that obtains with an ideal op-amp.
Spehro Pefhany
...Jim Thompson
Simplified case, unity gain inverting summing amplifier, consider
finite gain only.
Op-amp: Vo = -AoVin
| ___ | >----+----o Vo
Vx o-----|-|___|-+ -|-/ |
| _R_ | |/| |
+-|___|-+ |
| _R_ | ___ |
+-|___|-+---|___|--+
| R |
| etc. N inputs
| ___ |
+-|___|-+
| R
GND
Vin = (Vo/R + Vx/R) * R/(N+1)
Vo = - AoVin => Vin = -Vo/A
-Vo/Ao = Vo/(N+1) + Vx/(N+1)
-Vo (1/Ao + 1/(N+1)) = Vx/(N+1)
Vo/Vx = -Ao/((N+1) + Ao) (closed loop gain)
~= -1 for Ao >> N+1
Best regards,
Spehro Pefhany
F
Fred Bartoli
No, you're discussing the same configuration, a summing inverter with N
equal gain inputs.
From the POV of _one_ input, the equivalent schematics reduces to:
R1 R
___ ___
Vin -|___|------+-----|___|-.
| | >--+--Vout
R1/(N-1) | | |
'-' GND
GND
(created by AACircuit v1.28 beta 10/06/04 www.tech-chat.de)
Obviously the gain is (about) -R/R1, but the noise gain, i.e. the loop gain,
reduces from G(w)R1/(R1+R) for the one input case to G(w) R1/(R1+N R) for
the N input case.
Suppose you use an OP77 (700kHz GBW product) you want gain=-2, have 5 inputs
and need 1kHz BW, then your loop gain is only 700/11 = 63. Not that much,
and easily further reduced as asked higher gain or with input numbers.
One cute trick if you have an opamp to spare, or you add another one because
you want improved performance, is to add a negative resistor between the
minus input and GND.
R1 R
___ ___
___ | |\ |
.-|___|---+------------+-----|-\ |
| | | | >--+--Vout
+--< | R1/(N-1) | | |
| \| | '-' GND
| ___ | |
'-|___|---+ |
.-. GND
GND
You'll have to pay attention to some stability pb if you want to push the
limit, but if you want a reasonable loop gain (say maybe 1/3 to 1/4 of the
main opamp gain) this is easy to use.
Larry Brasfield
Fred Bartoli said:
..., but the noise gain, i.e. the loop gain,
Those two concepts should not be confused. The
term "noise gain" refers to the closed loop gain for
a signal arising between the amplifier inputs, while
the term "loop gain" refers to the gain around the
loop consisting of the forward path from amplifier
input to output and the feedback path from that
same output to that same input.
F
Fred Bloggs
Larry said:
(Responding to the question: "If an OP-77 connected as simple
inverting summing op-amp stage has N inputs, how could you
estimate the practical limit for N ?")
You amaze me, Fred. You show signs of some
intelligence but seem to have never applied it to
understanding your own limitations.
That is a response to be expected from a pretentious little punk
pseudo-intellectual like you. We know you are the PUNK born again xtian
maggot from Washington state who has been plaguing the NG with his
superficial trash for some months now.
Do you deny that loop gain imposes a practical
limit on how many inputs a summing op-amp
circuit can have? If so, you are the one that
needs remedial training in op-amp theory.
If you are merely suggesting that the limit I have
stated is never applicable, why have you not
given some hint as to what the real limit on N is?
My bet is that you cannot.
You're quite unimpressive to look at your posting history. You spout a
bunch of pseudo-theoretical elementary garbage, typical of a punk
know-nothing 2nd rate EET student or wannabe, and soon evaporate once
the thread becomes focussed. You certainly skulked out of the encoder
divider thread without doing much of anything other than putting on airs
about being an experienced motion controls designer- which we know now
is a despicable fiction. You're a cowardly little hypocrite born-again
xtian maggot and a hot air bag.
F
Fred Bloggs
[..snip Woodgate drivel...]
For that topology, the feedback gain is:
(1/N) / (1 + 1/N) == 1 / (N + 1)
Clearly, as N approaches the open loop
gain of the op-amp, the loop gain will be
approaching 1. This means that the gain
accuracy will be reduced relative to the
usual case where loop gains exceed one
by quite a bit.
What a bunch of pseudo-intellectual garbage- and look at that damned
complex math- and who the hell waits until loop gain gets near one to
conclude they have an "accuracy" problem? What a pile of horse manure!
Consider the formula for
closed-loop gain:
Consider? Consider?! You really are losing it. Who the hell are you to
tell anyone to consider that pathetic, boring, and irrelevant pedantry-
what a damned joke- stinking moron regurgitating trash from his textbook.
Usually, we neglect the 1/G term because
it is small relative to H. But as N becomes
comparable to the open-loop gain (G), that
simplifying assumption becomes invalid.
What a bunch of retarded crap- the moron is so damned dumb he/she/it
thinks a working engineer with 60+ years of practice needs that low
level minutia explained to him. What an unbelievable little wimp punk
born-again xtian scumball.
F
Fred Bloggs
Larry said:
I can remember designing a number of op-amp circuits...
Ahh- you did some homework on your own...whew-i-m-p-r-e-s-s-i-v-e.
[ snip boring pedantic drivel...]
Larry Brasfield
[Cut a load of non-electronics related ad hominum crap.]
I note that you have well developed name-calling skills,
but are unable to answer the challenge I posed. I take
this to mean that your "review OpAmps 101" suggestion
is nothing but empty pretense.
You can take this as my response to your other two
content-free posts.
F
Fred Bloggs
Larry Brasfield wrote:
[...snip usual pretentious Brasfield- fake name trash...]
content-free posts.
You should talk about "content-free" posts, you little punk, superficial
engineer wannabe. Hey!- Where's your "tricky" current source, maggot?
Don't bother playing your trump card about having nothing to prove,
because so far you're just a skulking little punk hot air bag.
how many inputs you can have (actually how low a shunt resistance
you can tolerate) must include the gain bandwidth required, as well
as the opamp in question.
So could this ever be considered a legitimate technique for gain /
slew-rate adjustment? Or is it just too stupid?
