Joerg
- Jan 1, 1970
- 0
Spehro said:You could probably do it if you could run a few coax or triax lines to
the place of measurement, but that sounds.. challenging.
I think they would flog me if I'd just mentioned that
Spehro said:It's not NE wire... we do deal with them regularly.
A quick look, can't find them (they showed up at a trade show and I
talked with them a couple of times, but we ended up designing our own
coil winding machine). 8-(
Joerg said:Essentially it's measuring minute changes of a variable capacitor. It's
only 6pF and the variation is +/-0.5pF full scale. The capacitor is
going to be 0.008" width and height. This is wired up as a super-tiny
resonant circuit and, after 5ft of not very ideal cable we'll have to
detect the resonance and track it. IOW, the system has to extract the
FM-modulation and quiescent bias in this signal. In order for this job
not to become too simple or boring, this is all going to be immersed in
fairly conductive fluids.
Sounds all simple but when you have to do all this (less the
electronics) in a metal cylinder of under 0.015" O.D. it becomes
non-trivial. The challenge is that the coil can't be too close to metal
or fluids or the Q and thus the resonance would almost collapse.
John said:The Boonton uses a phase-sensitive detector, at 100 KHz or 1MHz, and is immume
to cable capacitance. But to do that sort of 3T c measurement, you'd need two
coaxes, or n+1 if there are n caps to be measured.
Or TDR it.
Dimitrij said:Ouch! Looks decidedly non-trivial.
Whatever you end up doing, beware of the temperature dependence of ferrites.
Unless the temperatures involved are practically constant, getting the
resonance of a ferrite-core inductor stable over temperature may prove a
considerable headache.
Recently I've been bitten by this less-than-well-documented property of some
no-name ferrite. Got a new, but rather inexpensive spectrum analyzer and
found out that it would not track the signal of it's own built-in tracking
generator. When turned on, set to 20 kHz RBW, and connected directly
output-to-input it would see no steady signal, just wavy lines on the
screen, resulting from slope demodulation of some PLL's loop ringing, the
receiver's center frequency being way off-center from the TG. As it warmed
up, ca. 20 minutes later, it would slowly drift into the frequency it's been
adjusted for at the factory and show a stable signal for a while. After 1-2
hours, as it heated up even more, it would drift out of tolerance and the
signal would slowly disappear into wavy lines again. At 400 kHz RBW however
all would look well all the time.
The manufacturer from Shenzhen seemed to hardly understand the issue, and
shipping the thing back looked like a lot of hassle and additional expenses,
so I ended up repairing it instead. I found out that the receiver's third IF
stage was done with LC filters, the Ls wound on some unknown ferrite core
(all 6 Ls in the rather symmetrical filer being equal). The Cs were NPO and
had sufficient stability, but the ferrites were really drifty, although all
equal to each other (which fortunately made the whole filter drift equally
in one direction and not spread).
In the end, I ended up replacing the local crystal oscillator that was
driving the mixer of this stage with a wide tuning range (350 ppm) VCXO
(plus a little amplification and filtering on the VCXO's output) and using
an LM34 temperature sensor plus an opamp to control the VCXO's frequency.
The LM34 was put into the drifty third stage module near one of the filters
so it could track the temperature. After setting this up, running the
spectrum analyzer throug some 5 or 6 temperature cycles and adjusting gain
and offset of the newly-added 'compensation' as it went, I finally got it
sufficiently stable. It ended up with a below 3-ish kHz drift over
temperature as opposed to the manufacturer's originally specified 10 kHz and
the actual measured 50 to 70 kHz drift when I first got it. A factor of 20,
more or less, and no more wavy lines.
When I finally had a look at the service manual that they decided to send me
after some waiting, and found there instructions to calibrate the center
frequency after at least half an hour of operation, somehow I was no longer
surprised. So much for ferrites and their more insidious propertied.
So, if you end up with a micro-miniature ferrite in your application, and
need to track it's resonance frequency, make sure to design in some local
temperature sensing, so you can correct out the nonlinearities later. If
that's not possible, make sure to select and test the ferrite very well.
Sure, given your well-known profession, if it's a medical device that can
take a more or less 36.6°C environment for granted, the above may not apply,
it also won't apply if you are only interested in the changes of the
frequency and can safely ignore the absolute value. Otherwise a ferrite-LC
may go well with some compensation.
Spehro Pefhany said:BTW, Tim W., ...
<snip>Recently I've been bitten by this less-than-well-documented property of some
Jim Thompson said:But it's go-o-o-od eats!
Jeff Liebermann said:Well, if that's all you want, just take some 1/4" mylar recording tape
and wrap it around the wire or form it into a spindle. You won't get
much AL out of whatever mix is used for recording tape, but if you're
lucky, it might be enough. It's certainly easier than making your own
tiny rods.
Mmmm.. looks like it would be good with smoked porkchops (Kasseler)
Spehro Pefhany said:Mmmm.. looks like it would be good with smoked porkchops (Kasseler)
from our local Euro meats place.
Do you recommend with or w/o horseradish? Generally I'd probably
prefer the latter.
Looking for a way to either buy very tiny ferrite rods or have them made
somewhere. Like this:
http://www.fair-rite.com/cgibin/cat...ircuit&THEPART=Antenna/RFID+Rods#select:freq1
Except that we need to get the diameter down 0.004" (0.1mm). Length
0.120" to 0.160" (3-4mm) but that's easy to cut. We need to make coils
with these ferrites that will be used in the >10MHz range, so 43, 61 or
67 material would be ok.
Spehro Pefhany said:<snip>
Care to mention the maker? Atten?
Jasen said:can you stick an oscilator in there? A 555 die is not going to fit, but
perhaps there's something else that would.
Jeff said:Well, if that's all you want, just take some 1/4" mylar recording tape
tiny rods.
axolotl said:Getting ferrite down to .004 may be a bridge too far. You may want to
look at shaving off a sliver of .004 amorphous steel. For
experimentation, you can find a piece in the anti theft tags of your
next big box store purchase.
Martin said:Not French, but my favorite....
<http://www.abauersmustard.com/>
Hey, google "metglas wire." The stuff apparently exists. It's an electrical
insulator, essentially a metallic glass, but has permeability up to 1e6, if you
treat it right.
Considering the family name probably a Bavarian recipe. Maybe from
great-great-great-grandpa back in Europe.
